The tires that were on my '72 when I purchased it have gone south on me. Tire sizing is not exactly my comfort zone and don't know a lot about it. The current tires I have are P275/60R15. I have a neighbor down the road that has some tires that are P265/70R15..... What will be the difference, the height of the tire? Or how does that work? I'm assuming that the 15 is the size of the wheel itself, so that should be a doable thing.....or am I off base on this? Thanks
![]() Join Date: Mar 2012
Re: Tire Sizes....???
https://tiresize.com/converter
try this , I am thinking they will be the same since you are going bigger on the sidewall but less on the width
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Losing not quite half an inch in width and gaining just under and inch in sidewall height.
275 mm width to 265 mm width The sidewall height is the next number as percentage of width, 275 x 0.6 = 165 mm For the 265/70-15 the sidewall is 265 x 0.7 = 185 mm The overall diameter of the 265 tire will be 2x the sidewall difference so that would be (185-165) x 2 = 40 mm about 1.6" bigger diameter.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
thanks guys. I just need these to make it to where I can move the truck while it's being worked on. I'll eventually go with something better once all the important stuff is fixed and running again. I appreciate the info!
Post Whore
![]() Join Date: Feb 2016
I was going to say the biggest difference between the 2 sizes would be the change in overall rear ratio. But for your current plan that wouldn't matter, unless the front end of the truck has been lowered a bunch.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Here is a tire sidewall chart I built trying to decide what diameter rim and tire size I want. This is the tire sidewall x 2 changed to inches. Add this number to the rim diameter for the overall diameter. The stock tire was about 28.8". Please note that not all diameter tires are available in all these sizes. This is just a guide.
What I haven't been able to find is what is the largest diameter tire you can run with stock suspension......I think it is about 30.5 to 31" but not sure. I don't know how to upload an Xcel file so it is just a picture. |
Junior Member
![]() Join Date: Jul 2014
cj847 I can tell you the max must be more than 31 because I have 31X10.5X15 on stock height and it fits fine (and looks just right IMHO).
40 years ago in high school I ran a 32 x 11.5 x15 on a 72c10with stock suspension and had no issues
