Old 09-24-2020, 10:11 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
QJet running fat
Hi guys, my DD project is getting down to little punch list stuff
fixing a tiny rear diff leak this weekend, but while I am at it I want to tune the carb a little. It runs high idle at cold idle, I corrected that this morning taking it down to about 1k RPMs from1300. but it still runs very fat, a lot of gas smell and the front of the carb is gooey. I had the carb rebuilt last year and have done the tricks with leaning it out and then bringing it back a quarter etc... I even opened it up once and sprayed it out thinking the needle wasnt seating correctly.
Any tips? It runs good sounds good but I would like to quit wasting gas and smelling it
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 09-24-2020, 10:36 AM   #2
68Gold/white
Re: QJet running fat
Posting your carb number will help. All Quadrajets are not ALL the same...tuning wise
68Gold/white is offline   Reply With Quote
Old 09-24-2020, 10:41 AM   #3
phlegm
phlegm's Avatar
Thanks! I will
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-24-2020, 10:46 AM   #4
Richard2112
Richard2112's Avatar
I'm still running the Q-jet I overhauled a few years ago. It was doing the same thing, running rich and seeping fuel. I put new floats in at the time and re-adjusted the level. Thought I would have to rejet but it's run well since the overhaul. It's sorta difficult to tell but the floats can become saturated over time and won't work exactly as intended.
However as has been stated, not all Q-jets are the same. A number helps.
Richard2112 is offline   Reply With Quote
Old 09-24-2020, 11:27 AM   #5
68Gold/white
Take some pictures, also...top. front, especially. If you had the top off, was the float brass or plastic (black in color)?
Old 09-24-2020, 11:48 AM   #6
phlegm
phlegm's Avatar
7041211 IT
0691 ---. can't see all this one
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-24-2020, 05:21 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
7041211 Shows up as '71 350 CI engine. The other info is build date, and then probably the rebuilder's own code. You can weigh the float. The composition float weighs 8 grams if it isn't saturated with fuel.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 09-24-2020, 05:53 PM   #8
phlegm
phlegm's Avatar
I will have to find some scales, I havent had a set that measured grams since college
that may be it, maybe he put the wrong float in? not sure.
Anything else to check while I am in there? Of course, go ahead and spray it out, cause why not...
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-24-2020, 07:54 PM   #9
geezer#99
geezer#99's Avatar
I wouldn’t open it yet!
Clean it off and then definetly see where the leak is.
Looks like the base plate gasket might be the culprit. Evidence of that is the soot trail from the vac hose connection and by the fuel inlet. No evidence of flooding though. That usually shows up on the ends of the throttle shaft and leaves a dark stain on the intake walls.
Old 09-24-2020, 08:18 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
I was going to ask but forgot. What is that guck at the air horn/float bowl gasket area?
~Steven
Simi Valley, CA
Old 09-25-2020, 05:14 PM   #11
Sim6
Sim6's Avatar
I'd pull it and see if the bottom of the jets are leaking. I have had to JB weld the bottom of all the jets on my quads. two front ones you can see without removing the base. the back two you'll have to remove the base. This a common issue and should be looked at first in my opinion.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
