Old 09-24-2020, 12:59 PM   #1
kglowacky
vent window interchange
Now working installing my door vents and windows. Do9es anyone know if all vent windows frames are the same from 73-86. When I try to install my vent window frames there seems to be an issue on a little bracket right below the vent handle side that spreads the door apart. I could cut this bracket off but before I do I was wondering if I have the wrong vent windows as I did have the wrong regulators and motors. Also my door glass has a black square painted on it . It looks factory anyone ever seen this before. I can scrape it off . See pictures.
kglowacky is offline   Reply With Quote
Old 09-24-2020, 02:48 PM   #2
TKCR
TKCR's Avatar
Re: vent window interchange
The vent windows are NOT the the same from 73-87. Not sure when the change was. Probably late 70’s
Old 09-24-2020, 03:23 PM   #3
kglowacky
do you know what the differences are? Can anyone tell what year I have.
Old 09-24-2020, 06:42 PM   #4
v30crewcab
v30crewcab's Avatar
that window looks like its from a 89-91 suburban with the power mirror option.
theres at least two vent window styles. the 88-91 are one piece gasket, the 87-older are 2 piece gasket. I'm not sure if the 73-76 are different but possibly.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-24-2020, 06:51 PM   #5
kglowacky
will they interchange? I assume the black out is for the power mirror. I bought this truck in boxes and know for a fact I got a whole lot of parts from a suburban. The PO told me that and said all would interchange and HE WAS WRONG. LOL that's part of the fun. Found another challenge today. The door glass rear window channel guids that go in the door up against the door lock have me stumped at this point ,was thinking incorrect also as I cant figure any way they bolt on. But Classic shows 73-91 to be the same. there are in great condition. The fun continues
Old 09-24-2020, 09:30 PM   #6
73-80 is one style, 81-87 there is a 2 piece seal version. 85 and up there is also a version with a 1 piece seal.
I honestly don't know if they are interchangeable for the pre 81 and81 up models or not. I don't remember the dor change exactly, I think it was around 77. With that being the case, I would think you could use either style in any year. LMC sells a complete set that is advertised for all years
Old 09-25-2020, 12:25 PM   #7
kglowacky
just installed the drivers vent window and window. They do interchange with what ever year Suburban I may have. Thanks for the help
