09-24-2020, 02:48 PM | #1 |
Need tips on replacing heater cor on my 72 Jimmy
Hi, Going to replace my heater core very soon. Jimmy has A/C any tips or info will be greatly appreciated. I know it is a hassle to change. Thank you.
09-24-2020, 07:03 PM | #2 |
Carpe manana
Re: Need tips on replacing heater cor on my 72 Jimmy
Drop the inner fender right off the bat. Line the interior with something to catch any leaking fluid.
The repro cores can be ill fitting I’ve read. OEM cores can be repaired and reused. Check with Classic Heartbeat or GMC Paul if you plan to use a new core as they may have a better fitting example than a bigger retailer.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-25-2020, 04:48 AM | #3 |
Agree with DeadheadNM's recommendations. Have not done one for some time. Last time I saw an aftermarket it was thinner and did not fit correctly or heat as well. If you have a local radiator shop see if you can have the stock one repaired or re-cored.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-25-2020, 11:11 AM | #4 |
Thanks Guys. Starting this weekend.
