09-27-2020, 11:32 AM | #1 |
Torque Covertor Questions
I have a 72 C10 longbed. My original 350 went south, so I bought a 350/290 crate engine. It was considerably less expensive than rebuilding the original 350.
It is kind of a pig and rather sluggish. Even my shifts are lousy and sluggish. The paperwork with the engine says it has a higher rpm powerband and may require a higher stall speed convertor, contact your convertor company, but no guidance. So far, every company contacted is trying to recommend more of a racing convertor. I don't care about 1/4 mile times. I am planning no drag racing or street racing. I just want better drivability and fuel mileage and a smoother shifting truck. Any suggestions, or companies to contact? |
09-27-2020, 11:58 AM | #2 |
Re: Torque Covertor Questions
Wrong motor if you want drivability and mileage. No compression, too much cam, crap heads.
Likely needs a 2500 stall. What was recommended? What trans and rear gear? |
09-28-2020, 01:41 PM | #3 |
Find out what cam is in it. That is the first step to see what kind of combination it was built for.
1969 C-10 Supercharged 355 12.20@104 1968 Firebird Nat.Asp. 355 12.50@106 2002 GMC 2500HD Duramax 13.0@104 |
09-29-2020, 09:36 AM | #4 | |
09-29-2020, 11:04 AM | #5 |
I tend to doubt that your problems are solely due to a torque converter.
Will it idle OK with light pressure on the brake? If so, it should be fine. What is the recommended idle speed? Do you have enough vacuum that your brake booster still functions ok? 290 hp should not feel sluggish. Is it just sluggish below 2000 rpm? I would take it out on the freeway and open it up. If it performs poorly at 3000 rpm it is not the TC. |
