Old 09-27-2020, 03:49 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Dangerous Lesson Learned...
I wanted to throw this out there for the safety of other board members, and anyone else reading the board.
Recently I was driving my heirloom 68 LWB stepside C10 down a country road as I have done hundreds of times before. All of a sudden the rear end went airborne and came crashing down to the road again. As I was wondering what the devil had just happened, I noticed a very familiar-looking spare tire bouncing down the road in the rear-view mirror behind me. It came to rest in the ditch, so I stopped and threw it into the truck bed.
So here is apparently what occurred: I put this brand-new spare tire under the truck into its factory-correct bracket several years ago. In all that time I hav
e NEVER had a flat with this particular truck. So, as they say, out of sight, out of mind.
Over the years, the air in said tire had gone down a bit as tends to happen with unused tires. So as I was driving down the road, the now-smaller tire apparently worked itself loose from the spare tire bracket, and the front of it touched down on the road. This literally pole-vaulted the rear end of the truck into the air and unleashed the spare tire onto an unsuspecting public roadway.
I shudder to think of what could have occurred had this happened on the interstate highway. The tire would have undoubtedly hit other cars and ping-ponged back and forth between the interstate dividers, striking fast-moving vehicles as it went, since it would have had nowhere else to go. And I would have been driving interstate speed, so this also could have caused the truck to flip over, or loss of control and a terrible accident.
I thank my lucky stars that I was driving only 40ish MPH on a deserted country road when this occurred. So I am saying to everyone reading this:
CHECK THE AIR IN YOUR SPARE TIRE EVERYTIME YOU CHANGE YOUR OIL OR SIMPLY THINK ABOUT DOING IT.
It may save a life, including your own.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 09-27-2020, 03:58 PM   #2
mr48chev
mr48chev's Avatar
Re: Dangerous Lesson Learned...
Dang, I was looking at the spare on a truck that I drive quite a bit the other day thinking that I needed to check the air pressure in it. My 71 has the spare tire holder on the inside of the bed and the tire stands up in the left front corner of the bed if I have it in there.
My ongoing truck projects:
Old 09-27-2020, 04:31 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Dangerous Lesson Learned...
Good thing you where on a country road. Glad your OK.You may need to check under the truck make sure nothing was damaged. I removed the old tire rack years ago and keep my spare in the bed. Which I have a bed cover over it also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-27-2020, 04:47 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
IF you decide to repair, and return to using the underbed spare tire carrier -- you might consider 2 independent safety chains going to points under the bed. May have to be fabbed. Each chain thru the rim and around the rubber. Close to 180* apart. Sufficient to hold the tire by themselves. It would make changing a tire in the rain and dark an even worse situation than it already is, but there would be peace of mind that your spare is bombproof.
Old 09-27-2020, 04:56 PM   #5
rockyrivermark
I had that happen to me on a 1981 C10. Same exact thing.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 09-27-2020, 06:41 PM   #6
truckster
truckster's Avatar
The spare tire is often neglected, unfortunately. Not only are they allowed to lose their air, people run with spare tires that are 20 years old and dry rotted to the point they would be unsafe for any distance.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-27-2020, 08:09 PM   #7
Leonard1
Leonard1's Avatar
I check mine every oil change, not for that reason, but because it sucks having a flat only to discover the spare is flat too.
Leonard1 is offline   Reply With Quote
Old 09-28-2020, 07:58 AM   #8
67C10Step
67C10Step's Avatar
As I as reading through the posts in this thread I was thinking this exact thought. If I don't remember to check it at every oil change every other oil change my tires get rotated and they all get checked then.
Thanks for the warning though. That would have been crazy on a multi lane 75-80 mph highway!
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-28-2020, 05:02 PM   #9
Sheepdip
Sheepdip's Avatar
Mines easy to check the air in, made this sun cover awhile back and left the center open for easy valve stem access.
Sheepdip is offline   Reply With Quote
Old 09-28-2020, 05:15 PM   #10
weq92f
weq92f's Avatar
Dang! That could have been so much worse. Pretty sure you would have crashed at higher speed.
Glad you are OK!
I've always been wary of flat spare tires...never considered one might fall to the road as a result though.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-28-2020, 11:58 PM   #11
External
External's Avatar
Thank you for the lesson. I will take notice.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 09-29-2020, 07:19 AM   #12
Stormin08
Stormin08's Avatar
i had a lowered truck loose the spare while turning onto an ON-Ramp...it lifted and allowed the truck to slide to the left, slamming the rear wheels into a large curb when coming down.
ripped the roll pan off, broke the wheel and bent the axle shaft.
Stormin08 is offline   Reply With Quote
Old 09-29-2020, 08:00 AM   #13
A thing to not take for granted for sure. What good is a flat spare tire anyway?
Old 09-29-2020, 11:50 PM   #14
'68OrangeSunshine
Back when I ran bias ply tires [guess we all did then] I kept an innertube in the spare, so it wouldn't serarate from the rim when offroading.
