Old 09-27-2020, 07:12 PM   #1
44th Miss Inf
85-up hydraulic clutch part nimbers
Here is a list of part numbers for the 85-up hydraulic clutch system. Some parts ARE still available at GM. Some may be superseded but you should still be able to search using these. Some are listed as GM calls then, some by common name.
Hope these may can help someone
15530202 Bellhousing
15592270 clutch throw out fork
15590132 boot, clutch fork
15592268 stud, clutch fork ball
15594154 clutch reservoir
15590106 clutch reservoir bracket
15584903 cap kit, clutch master reservoir (includes 2 parts below)
15594155 cap, clutch reservoir
15594156 seal, cap, clutch reservoir
15546558 hose, reservoir to master cylinder
19158669 clutch master cylinder
15537760 hose, clutch master to slave
15615868 clutch slave cylinder
15592279 gasket, clutch slave cylinder
15592273 pedal assembly, clutch
15592276 spring, clutch pedal return
00346381 bushing, pedal
12338127 bumper, clutch pedal (rubber)
15598491 switch, clutch safety
15521991 brace, outer, clutch master cylinder
15522108 brace, inner, clutch master cylinder
44th Miss Inf is offline   Reply With Quote
Old 09-28-2020, 05:20 PM   #2
1774btcrew
1774btcrew's Avatar
Re: 85-up hydraulic clutch part nimbers
Awesome!Thank you for doing that!
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
