Old 09-29-2020, 02:19 AM   #1
Asshat
Asshat's Avatar
Smoke on acceleration - video
I’m going to do a compression check to see if it’s the rings. Once I got everything together, there was not really any smoke coming from the exhaust. However, when I blipped the throttle, smoke came from the exhaust; bluish hue. I figure the valve stems are probably ok.
And, since I’m going to have the trans out of the truck, it might be a good time to pull the motor if the rings are bad.
Just checking to see if my thinking is correct on the smoke @acceleration. What do you guys think?
Also, how do I determine what size rings I need for my pistons?
Trying to post link to video- hope this works:
https://youtu.be/sSD6IEEq-Is
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 09-29-2020, 06:35 AM   #2
bsarts
bsarts's Avatar
Re: Smoke on acceleration - video
I watched the video, are you talking about the smoke coming from the breather? If you're getting noticeable increase in fumes/smoke from the breather as you rev. the engine, especially with no load, I'd say your due for an overhaul. Blue smoke from the exhaust means you're burning oil, but it could be from the valve guides too.
The size of rings that you need will be determined after teardown and depending on whether it needs machining.
bsarts is offline   Reply With Quote
Old 09-29-2020, 06:39 AM   #3
Asshat
Asshat's Avatar
When I revved the motor, the smoke was more prominent from the leaking exhaust pipe and muffler.
292, 4-speed
Old 09-29-2020, 08:27 AM   #4
nsb29
nsb29's Avatar
It’s time for an LS
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 09-29-2020, 09:21 AM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Needs rebuilding. That's blow-by coming out the breather cap- combustion gases leaking by the rings. The rings are shot.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 09-29-2020, 09:26 AM   #6
geezer#99
geezer#99's Avatar
I could cure that smoky breather in two shakes.
So could you Steve if you look closely.
Old 09-29-2020, 10:59 AM   #7
Asshat
Asshat's Avatar
How would you do that?
292, 4-speed
Old 09-29-2020, 03:25 PM   #8
Asshat
Asshat's Avatar
Did compression check, all cylinders 155-165. Added oil to each and no increase in compression readings.
Maybe it’s just valve guides?
292, 4-speed
Old 09-29-2020, 03:49 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, buddy!
Asshat- Put a PCV valve on that valve cover and connect the hose from it to the carb! That'll at least recycle the smoke. I thought you were getting smoke out the tailpipe. That accelerator pump or the circuit need a little help to get that stumble out when you speed the engine up.
~Steven
Simi Valley, CA
Old 09-29-2020, 04:00 PM   #10
Asshat
Asshat's Avatar
Originally Posted by Steeveedee View Post
Yeah, buddy!
In the video you should be able to see the new PCV valve.
And, I am getting smoke out of the tailpipe.
292, 4-speed
Old 09-29-2020, 04:19 PM   #11
geezer#99
geezer#99's Avatar
Might be new but it does nothing if it’s not hooked up!
Old 09-29-2020, 04:56 PM   #12
Asshat
Asshat's Avatar
It's plain as day, it's right in the first part of the video. The hose from the manifold goes to the PCV valve.
292, 4-speed
Old 09-29-2020, 06:01 PM   #13
nsb29
nsb29's Avatar
The only hose I see of the intake goes to the steering column but if it’s smoking from the exhaust it don’t matter
Old 10-03-2020, 03:16 PM   #14
Asshat
Asshat's Avatar
New video.
https://youtu.be/7jyLDeL3MMk
292, 4-speed
Old 10-03-2020, 06:52 PM   #15
AcampoDave
AcampoDave's Avatar
Any idea how many miles are on that engine?
AcampoDave is offline   Reply With Quote
Old 10-03-2020, 07:27 PM   #16
Asshat
Asshat's Avatar
No idea. That is why I am pulling it.
Going to check the pistons and bearings.
292, 4-speed
Old 10-05-2020, 05:52 PM   #17
Asshat
Asshat's Avatar
Debating on whether I should just re-ring the pistons and hone the cylinders or send this off to a shop and get everything re-done.
I am inSouth Orange County CA, so there's not any shops right around me. Everything is up towards Santa Ana and Orange. Anyone have a shop they used in this area?
What would you guys do if you were on a limited budget?
292, 4-speed
Old 10-05-2020, 06:08 PM   #18
mongocanfly
Post Whore
mongocanfly's Avatar
This is what everybody is looking at I think...when the say the pcv not hooked up
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-05-2020, 06:14 PM   #19
Asshat
Asshat's Avatar
Originally Posted by Asshat View Post
Yeah, that was in the first video I posted. However, I did pulg in the manifold vacuum hose to the PVC, and it still does smoke as seen in the latest video above.The motor is out of the truck, so at this point it doesn't really matter.
292, 4-speed
Old 10-05-2020, 06:47 PM   #20
mongocanfly
Post Whore
I got ya..good luck with the rebuild...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-05-2020, 06:59 PM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
Your primary concern for how to approach either rebuilding it or just a ring job is to assess the cylinder walls. Is there a ridge near the top where the piston rings stop going up on the stroke? Do you have some inside calipers that can reach into the bore and measure for ridge thickness and taper?
I'd like to see a piston to look at the oil control rings. Even with good compression if the oil control rings are not wiping the cylinder properly, it's still going to smoke. Do you know anyone on the board knowledgeable enough to help you with that assessment? I'd look at it but I'm about 60 miles away, and I loathe driving the 405 after about 27 years of doing that.
~Steven
Simi Valley, CA
Old 10-05-2020, 08:21 PM   #22
Asshat
Asshat's Avatar
I may be able to borrow some inside calipers from work. It’s been about 30 years since I rebuilt a motor, so I am a bit rusty. When I get the block disassembled I can post some pics. I really don’t know anyone on the board that is near me. I’ll have to some checking around and see if there’s a machine shop nearby. The main problem is finding a shop/machinist I can trust.
292, 4-speed
Old 10-05-2020, 08:28 PM   #23
Asshat
Asshat's Avatar
There is a slight ridge at the top of the cylinder bore, about 3/8” below the block surface.
292, 4-speed
Old 10-05-2020, 08:31 PM   #24
geezer#99
geezer#99's Avatar
Pull the rings off one piston and check their fit and gap.
Use A feeler gauge To measure.
You might find none of the rings will stay in the bore to be measured though.
I’ve seen that on a 396 that burned a quart every 1oo miles.
Old 10-05-2020, 08:35 PM   #25
mongocanfly
Post Whore
Calipers won't be accurate enough to measure past the cylinder ridge and on down into the bore...you'll need telescoping gauges and micrometers..or a true bore gauge...
And ditto to what geezer says...
Mongo...aka Greg
RIP Dad
RIP Jesse
