12-15-2003, 06:12 PM | #1 |
3/4 ton springs????
I think the springs on my k10 are starting to sag a little. Well it will be awhile before i can do any of this, but i was curious. Could i put 3/4 ton springs on my 1/2 ton. WOuld it raise it much? Would they just bolt in, or would there be a lot of fabrication.
thanks
1972 k10 4x4 LWB (Sold in 2005) |
12-15-2003, 06:54 PM | #2 |
Post Whore
Here is a pic of my original 3/4 ton springs. There are a total of 6 leaves and then there is a stock block that is also in the pack. I am relatively certain you can just bolt on a set of these, but you probably will need new u-bolts.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-15-2003, 06:56 PM | #3 |
Post Whore
Here is a pic of the block that is also used.
12-15-2003, 08:19 PM | #4 |
Robert Olson Transport
ive done it on the later model years as long as the length of the springs are the same youll need to use the larger U bolts too on the truck and youll have to make sure your rear brake line has enough clearance
im actually going to leave the rears in the 76 im building cause i use it tow alot
12-15-2003, 10:56 PM | #5 |
its all about the +6 inches
63-72 c10 and c20 trucks have leaf packs separated 42.5" center to center, the 4x4's these years were the same as 1 ton spacing at 40"
12-16-2003, 11:39 AM | #6 |
that seems like it would work. I dont care about lifting it, i just want heavier duty springs for towing and hauling stuff.
12-16-2003, 12:54 PM | #7 |
Formerly yellow72custom
Keep in mind it will also ride rougher....but if you tow and haul alot of stuff, go for it.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
12-16-2003, 01:13 PM | #8 |
like i said, it may be a little while before i can sqeeze the old bank account for that. I just figured that i am going to need to replace the old springs sooner of later, so why not try and put 3/4 ton ones on.
Has anybody just swapped the springs out. No blocks or anything. any pics??
12-16-2003, 02:26 PM | #9 |
user # 2756
Just get an add a leaf for about $60 a set, and install them. I added one to the rear of my truck plus replaced the 1" block w/ a 2" block. Pics in link in sig.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
