Shift lever removal
How difficult is it to remove the shift levers? The truck is a 70 and has the granny low 4 speed and a 4WD transfer case. Both need to come off.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
![]() Join Date: Nov 2013
Re: Shift lever removal
push down and turn the retainer on top of the shifter...it will pop right off and the entire stick will lift right out
for the TC you will need to get under it and remove the linkage and the bolt that holds it to the adapter
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Thanks!
