Old 12-15-2003, 06:22 PM   #1
skokie
skokie's Avatar
Is it a posi?
How can you tell if you have a posi diff? Besides a burnout I mean
skokie is offline   Reply With Quote
Old 12-15-2003, 06:43 PM   #2
74bowtie
You can juck up your truck with a floor jack at the center of the rearend, the pumpkin and get both wheels off the ground. Spin one wheel the other should spin in the same direction.
69 Chevelle (Summer only ride, love to drive this)
72 Chevy Shortbox 4x2 (newest addition)
83 Chevy Shortbox 4x2 (project but its clean)
2001 S10 Ext. Cab 4x4 (daily driver)
74bowtie is offline   Reply With Quote
Old 12-15-2003, 06:43 PM   #3
Porkchop
Porkchop's Avatar
jack up the rear and spin one of the wheels. If the other wheel spins in the same direction, it is a posi.
I don't know how you would tell if it is a locker or something else other than by pulling off the differential cover.
Porkchop is offline   Reply With Quote
Old 12-15-2003, 06:43 PM   #4
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Take the cover off of the rear diff and look at it.
67Fleetsidedream is offline   Reply With Quote
Old 12-15-2003, 07:33 PM   #5
CPNEJR
CPNEJR's Avatar
If it was me I'd just do a big ole' burnout to find out or not
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-15-2003, 08:23 PM   #6
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Ask Mrs. Cleo!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-15-2003, 09:19 PM   #7
dinnut
dinnut's Avatar
jack up the truck. start it put it in gear and floor it. what follows will be simply awesome
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-15-2003, 09:21 PM   #8
67Fleetsidedream
and extremely dangerous.
Old 12-15-2003, 09:52 PM   #9
74bowtie
Take the fill plug out and dip in your finger, taste it. A one legger does not have much of a kick to it, but a posi BAM!!! kick it up a notch!! A posi has twice the kick.
Just kidding
Old 12-15-2003, 10:03 PM   #10
skokie
skokie's Avatar
I will pass on tasting it. As bad as it smelled no thanks. LOL After jacking it up just enugh to get the wheels off of the ground this is what I found. If you turn the right wheel to the left the left wheel turns in the opposite direction.
Old 12-15-2003, 10:22 PM   #11
74bowtie
Sounds like a 1 legger.
Old 12-15-2003, 10:25 PM   #12
67Fleetsidedream
Yep it is not a posi if the other wheel turn the other direction.
Old 12-16-2003, 12:57 AM   #13
69_hafton
Sleep-Deprived
69_hafton's Avatar
Unhappy
On some vehicles I've seen that the transmission
needs to be in gear (so that the driveshaft won't turn)
because the differential will cause the same response
from the wheels otherwise. I don't know if this is true
with GM's, but I've witnessed it with limited slip diffs.
on other vehicles.
Best thing is to get ready to change your gear oil, and
pull the cover off.
69_hafton is offline   Reply With Quote
Old 12-16-2003, 01:11 AM   #14
67cst
i love summertime
67cst's Avatar
good point 69 halfton...heres hoping anyways cause i jacked up mine and tried it this last summer and they went opposite directions so im gunna have to find out when i get it on the road, lay a patch and pray for 2 strips of rubber
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 12-17-2003, 08:47 AM   #15
CPNEJR
CPNEJR's Avatar
I still say just light em' up it's the esiest way if you don't want to burn the rubber off your tires just go to the junkyard and find some that fit that are bald and your off
