Old 09-30-2020, 09:00 AM   #1
D'Monsta
D'Monsta's Avatar
SM 330 Muncie 3 speed
Picked up an SM-330 3 speed trans from a guy that said it came out of a 69 Chevy truck with 4 bolt main 350.. I'd like to use it to replace an SM-318 but it's longer, I think 22".. the SM-318 is 17 inches long.. I guess I should have grabbed the driveshaft too but at that time I thought they were the same length.. Anyone done this swap before in a 60-66 truck?
D'Monsta is offline   Reply With Quote
Old 09-30-2020, 09:29 AM   #2
Old Truck Man
Old Truck Man's Avatar
Re: SM 330 Muncie 3 speed
Yes sometimes the front bearing retainer is larger on the full syncro trans. the rear splines might be different. the shift arms and collum linkage need modifying. you will likely have to shorten your driveshaft.
Old Truck Man is offline   Reply With Quote
Old 09-30-2020, 10:49 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
Shortening your driveshaft should be fairly easy to get done. Might have to swap slip yokes as well, but that depends on the output shaft splines of the old vs new trans
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
