09-30-2020, 06:54 PM | #1 |
'68 tow hook install
Is there a page in the assembly manual that shows this?
Reason why I ask is it seems the Lower mounting area of the hook is thicker than the upper mounting area. Did Chevy have a washer in between the upper mount to compensate for this difference?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
09-30-2020, 07:15 PM | #2 |
Re: '68 tow hook install
Is it me or is that hook on backwards?
09-30-2020, 07:37 PM | #3 |
Yep, backwards. Not the proper mounting holes either. Tow hook mounting holes are in the pic below.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-30-2020, 07:54 PM | #4 |
So Does the upper mount get an inside washer ?
Are the hooks in this pic backwards? I heard the hooks on the 67-68 were pointed forward, No? https://67-72chevytrucks.com/vboard/...ight=tow+hooks In this thread, they state the hooks point forward on the 67-68 https://67-72chevytrucks.com/vboard/...ight=tow+hooks Pics please, Is there a page in the Assembly manual that shows this?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA Last edited by Astro-Balls; 09-30-2020 at 08:08 PM. |
09-30-2020, 08:31 PM | #5 |
Never seen them mounted forwards, but I have not dealt with 67-68 trucks much. Found other threads for you http://67-72chevytrucks.com/vboard/s...ad.php?t=84811
http://67-72chevytrucks.com/vboard/s...d.php?t=218219 Regarding the washer, is not one side of the hooks flat?
09-30-2020, 09:43 PM | #6 |
If he flips them around they may be flat
09-30-2020, 11:37 PM | #7 |
Are there pics in the '68 assembly manual for tow hooks?
09-30-2020, 11:46 PM | #8 |
I don't know if there is a 68 assembly manual. I have a copy of the 67-72 factory assembly manual that I have used for 20+ years and have never seen any information on tow hooks.
10-01-2020, 12:11 AM | #9 |
not certain about the presence of a washer, but since it's been brought up, I believe 67-68 hooks were oriented with points fwd and outboard. Not in the assembly manual, but here are pics from the 68 4WD brochure:
10-01-2020, 12:27 AM | #10 |
Excellent verification.
Thanks Jocko.
10-01-2020, 10:13 AM | #11 |
Proprietor of Dale's Corner
Well I'll be dipped, I would have sworn they're backwards. I learn something new every day. Thanks Jocko.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man Last edited by Ol Blue K20; 10-01-2020 at 10:14 AM. Reason: add to message |
10-02-2020, 07:10 PM | #12 |
There is no Flat Side, the mounting areas are offset on both sides, here are some pics..
10-03-2020, 06:33 AM | #13 |
The only thing I can think of is spacer/washer. I have never looked at the earlier hooks much.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-04-2020, 01:04 AM | #14 |
Currently Blazerless
They were made that way for tbe 60 to 66 trucks, on those they were mounted sideways.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
