Anyone have a crl rear window powerslider?
http://www.crlaurence.ca/crlapps/sho...lID=1470&pom=0
I am thinking of purchasing one and I can't find any pictures of how the motor and cable look Or the switch they use. Do they mount without any modifications? Anyone who could post pictures I would appreciate it. |
![]() Join Date: Feb 2019
Re: Anyone have a crl rear window powerslider?
At $554.00 I hope it works well..
https://www.youtube.com/watch?v=NSpSSxgoRLs
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
I'm wondering why bother? The slider is 2 inches behind your head. Why add the complexity, what do you gain? More stuff to break
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
People who smoke or have Dogs like them, adds to the ventilation, ease to throw stuff into the bed.
my newer truck has a factory one but it is also a crew cab so it isn't very feasible to open it as the driver. I really like it in that option.
I did have a manual slider in my truck years ago and it was handy. I saw a mod one time that the entire back window went down and was power. I thought that was a pretty neat trick. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
![]() Join Date: Dec 1999
Had one in my 85. Not needed in standard cab for sure. Extended or crew cab would be nice. My dad had a glass business so I got it at cost when they were pretty new. As seen in previous post pic motor is attached to drive cable. It can be mounted to floor or lower back cab wall under window. Control is from a momentary left right rocker switch.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
i have installed one in my 71 GMC works real well, easy installation. It uses a simple rocker type switch, i mounted the switch into the block off plate below the sterring column
Any pictures of how you mounted the motor and where you ran the cable?
I can you a few pictures later, basically i moved the fuel tank to the rear built a shelf and a panel to close out where the tank was and mounted it to that shelf. The cable runs down the back passenger corner. It pretty much mounts in the center of the cab aganst the back wall.
