Any transmission line route examples for 700r4 on a 350 with Headers on a 66?
Before I start running new lines I wondered what the best route is. Any examples that you guys have would be appreciated. Ill be running the same headers I had on the old 350 for a while but plan to ram style manifolds if that makes any difference.
Here are some pics of what was there |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Any transmission line route examples for 700r4 on a 350 with Headers on a 66?
Looks like a standard rout other than theyve been moved around over the years.
Here is a clean example.
I used K and N fitting and hi pressure flex hose. I routed it along the top of my passinger side frame and drilled holes through my rad support in the channel next to the battery box. I out rubber grommets on the holes and route the line ls to the cooler.
http://s1299.photobucket.com/user/jb...23904108567829 |
#4 | |
That is very slick! |
| Bookmarks |
