![]() ![]() Join Date: Jan 2005
Temperature Gauge Reading Hot
My temperature gauge has been registering high temps whenever the engine is under load. I did a ton of searching last night and stumbled onto a post where someone had the same issue, but had confirmed that his coolant was not hot. He tracked the issue down to a bad voltage regulator. I measured my system voltage when revving the engine, and it was going way up to above 17 volts. The contact in my voltage regulator was fused shut. I replaced my voltage regulator with a solid state unit, and now my temperature gauge is reading normally. This site is such a great resource! I will probably convert to an internally regulated alternator at some point.
#2 | |
The Older Generation
Re: Temperature Gauge Reading Hot
Good job figuring that out. There is certainly a lot of info on here if a guy knows how to find it. You made it a pretty easy fix by doing your homework.... LockDoc
We live in an era where we can take credit for fixing things on our own by copying the work of others. It's still satisfying have the problem fixed though 😁
Was your regulator the factory external type, or internal in a new alternator.
I’m asking out of ignorance. I too have an issue with my Temp gauge showing hot, but have updated/replaced everything involving the cooling system, and have verified temps with an external thermometer. I have a new gauge but just haven’t installed it yet. My alternator (internal regulator) is about 25+ years old, so maybe that’s my issue? Any tips on how to check the voltage output. BTW my voltage gauge reads normal. |
#5 | |
Does anyone remember Deja News? Do you remember what entity purchased them back in 2001? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#6 | |
Ok good to know.
I should be able to do the same with mine ![]() |
