Too much carb?
Hello, I just had my 350 rebuilt. Nothing special but a mild cam and full rebuild. I think I may have ordered too much carb for my engine. I will be running the Edelbrock performer RPM intake and I bought a summit 750 cam carb. After some more reading I think I should have got the 600 CFM version. What are the issues associated with too much carb? I have not installed it yet so I can still exchange it for the smaller version. Thoughts?
Re: Too much carb?
Tuning!
Bigger primaries can cause a stumble just off idle. It can be tuned to not do that but likely you won’t have the ability to do that. You’d need to play with squirter sizes, pump timing etc. Not the best thing for a novice. I’ve done it but I’ve always liked to play on the edge. 800 dp’s and dual quads on bone stock 350’s. Normally I’d say a 750 is just right but I’d suggest you drop down to a 600. A 750 would be better if you plan future big power adders like heads, bigger cam. I think you want a no-fuss easy to own set up. Go 600. Here’s a pic of the dual quad on a bone stock 350. 1250 cfm when wide open. Pulled like a freight train from 90 to 120. |
#3 | |
Re: Too much carb?
Re: Too much carb?
Too much intake manifold and carb for a near stock 350. The rpm manifold is for higher rpms than you will likely see. An Edelbrock performer would be a better choice, with a 600 cfm carburetor.
Re: Too much carb?
X2 on the edelbrock carb, I had a summit carb once,could never get it dialed in,pit on a edelbrock,I have used about 6 edelbrocks over the years,love them, I ran a 750 cfm on my ZZ6 crate engine in my 1970,bit with yours a little more tamer,I would go with the 600
Post Whore
![]() Join Date: Feb 2016
Re: Too much carb?
You never mentioned what heads you are running?
What rear end gear ratio are you running? Is the 750 carburetor a spread bore or square bore? Stock manifolds or headers?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: Too much carb?
The 750 is a square bore. The truck has the 441 casting heads that have a little larger chamber. My truck is a 3 on the tree with 373 gears and I do plan to run a mid length header.
Re: Too much carb?
i ran an RPM intake on an 041 head 350 many years ago, 216@.050 cam, headers, four speed and 3.90 gears. It was a great combo and I did not notice much difference with a 600 holley vac sec (1850), 750 vac sec (3310), and 650 double pumper (4777).
settled on the double pumper in that application but had some compression, 10:1, was running sunoco 94 back then. and the stick helped. but it ran great with all three carbs. |
Re: Too much carb?
I'm running a 770 Holley with vacuum secondaries on my stock L31-R 350. I have a dual plane intake and dropped down two sizes on the primary jets but run really good. I already had the new 770 when I bought the motor.
Re: Too much carb?
Update, I went ahead and made the hour drive yesterday to the summit racing store in Arlington TX. That place is amazing by the way. Anyway I exchanged the 750 for the 600 CFM version. They agreed also I would be happier with the 600. Time will tell.
Re: Too much carb?
#12 | |
Re: Too much carb?
The only "issue" which I have found is that, with the secondaries being mechanically operated, I have to demonstrate much restraint when in a hurry, not to floor it until at least 2500rpm, otherwise there is not enough air flow for the secondaries to do their thing (which are MUCH bigger than the primaries) . The Carter TQ is my carb of choice because it is so fantastically quick and easy to tune it for both primaries and secondaries and idle. What I'm getting at is that I recon one CAN have "too much carb" but that actually means "too large primary barrels". This would result in lack of control where the tiniest throttle movement would cause huge changes in air flow - perfect for race situations but very bad for street use.
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
#13 |
Re: Too much carb?
If you are running vacuum secondaries you can get away with running a lot bigger carb than what is normally recommended. Depending on heads, cam, compression, ignition, and exhaust you may gain a few more horses.
I'm running a stock cam but I have MSD ignition with a 6al box, a stage 1 dual plane intake, long tube headers and 2 and 1/2 exhaust out the back. I dropped 2 sizes on my primary jets but my L31-R runs great with a 770 holley. I wouldn't change a thing. |
