Old 10-03-2020, 07:42 PM   #1
arcticman
arcticman's Avatar
1961 apache lwb stepside 4x4 help with value
Hello, can someone give me a value on a 61 apache 4x4 all original. 8ft stepside box 235/6 radio delete i have a 67 gmc swb wide side 4x4 that i know is a rare truck but i really have no knowledge when it comes to 60-66 my research so far says 2nd year for factory 4x4 last year of the apache cant find any production numbers or if there a sought after truck or a dime a dozen. Any help would be appreciated
thanks
arcticman is offline   Reply With Quote
Old 10-04-2020, 04:38 PM   #2
arcticman
arcticman's Avatar
Help 61 apache 4x4 lwb stepside
Hello everyone,
I found a really clean original 61 k10 apache LWB stepside. trying to gather some info on this year truck so i can get an idea of what its worth to make an educated offer. I realize this is the 67-72 message board. I posted on 60-66 message board yesterday but have only had 2 views and 1 response. i dont know maybe that tells me all i need to know? ( not much interest in these old trucks) hoping theres somone that can help. I read that it was the last year for the Apache and 2nd year for GM producing there own 4x4s, no production numbers keep back then.
Old 10-04-2020, 05:21 PM   #3
gmc684x4
Re: Help 61 apache 4x4 lwb stepside
How clean is the truck ?
Paint still daily driver shape ?
Rust in fenders ?
Rust in box?
How solid is the cab floor corners rockers and roof skin ?
Cab mounts ?
Still original motor ?
At a guess really clean 5 to 12 grand at a guess with out close inspection
gmc684x4 is offline   Reply With Quote
Old 10-04-2020, 06:39 PM   #4
bcfishon
Without seeing it its hard to give an opinion but with a vision in my mind of what you described I would guess its a 2500 dollar good deal to a hi end of 5 grand. That year is not the hot ticket right now but would be a desirable rig for those that like them,and if its clean and being that old I'm sure the value would only appreciate.
bcfishon is offline   Reply With Quote
Old 10-04-2020, 06:57 PM   #5
best view
Make sure it has that snort hood they don’t reproduce them and they make the truck I sold my 60 short bed 4x4 5 yrs ago frame off for 60000.00 if that helps pic will help
best view is offline   Reply With Quote
Old 10-05-2020, 12:26 AM   #6
arcticman
arcticman's Avatar
Heres a few pic
Old 10-05-2020, 01:03 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
The bedwood is in better shape than the deck in my '68 Stepside. Apache's a cool name, too. Much cooler than ''C/10,'' which sounds like a target in Battleship.
I prefer the 67-72 body style, but they did not skimp on sturdy steel body panels in that vintage.
In Arizona, in the cities, you have to get emission tested every year for any vehicle 67 or newer. The earlier trucks skate. In Alaska that's not an issue.
What engine does it have? With that stick, the tranny is likely an SM420, with a Granny low. Rockwell T221 transfer case. Good set-up for the bush.
Old 10-05-2020, 01:11 AM   #8
arcticman
arcticman's Avatar
im 200+ lbs i crawled in the back to look at the hubcaps that wood is solid no soft spots at all i was suprised.
Old 10-05-2020, 05:02 AM   #9
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
That seems like a good find. Here in so-cal they're out and about. New for 1960 was a new designation system for trucks made by GM. Gone were the 3100, 3200, and 3600 designations for short 1/2, long 1/2 and 3/4-ton models. Instead, a new scheme assigned a 10, 20, or 30 for 1/2, 3/4, and 1-ton models. Actual badging on Chevrolet trucks carried the series name system from the previous generation for 1960 and 1961: the 10, 20, 30, and 40 series, C and K, were badged as "Apaches", 50 and 60 series trucks were badged as "Vikings", and the largest 70 and 80 series models were marked "Spartans". The '67-'72 were named the "Action Line".
But my biggest thing is can you buy restoration parts?? <<That right there would make my decision.
desert-rat is offline   Reply With Quote
Old 10-05-2020, 11:20 AM   #10
cwcarpenter98
cwcarpenter98's Avatar
What's the asking price? If you want to buy the truck, that looks like a good candidate for purchasing. Check the rockers, cab floor supports, cab corners, door bottoms, fender bottoms, and front floor pans to see potential rust issues. Also look around the roof both above and below the drip rail. Those are the areas you should look at when looking to purchase any 60-66 truck.
If you currently own this truck and are looking to sell it, this thread will be closed.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-05-2020, 12:35 PM   #11
Short 3/4
Kind of hard for those of us in the lower 48 to advise on price, as I know where you are is a whole different economic game . That said, it looks like a good solid truck, with most parts as close as your local UPS driver. (or this forum). While short beds are the trendy thing these days, I have to admit a long stepper is very cool and unique. Being a 1/2 ton will make brake parts much easier to find, and even X-fer and closed knuckle front end parts are out there with a little searching, so don't let anybody tell you different.
Those hub caps, radio delete and pass side mirror post (if the solid cast type) are all nice hard to find bonuses.
If you go for it it should be a fun and unique truck
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 10-05-2020, 02:00 PM   #12
61K10
61K10's Avatar
looks good to me, depends if you want it and can afford it. Ck out my build (61K10 build) much info for you there. I would not sell mine for less than 25K. good luck. A couple of pics of mine.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-05-2020, 03:04 PM   #13
gmc684x4
Very clean shape almost all alaska stuff i see is from Haines and Juno very rusty trucks
With all the creases i see i will say 2500 to 5000 for it
Old 10-05-2020, 04:22 PM   #14
61K10
61K10's Avatar
Also the first few years of these K tk's not many were made.
1961 chevy K10
Old 10-05-2020, 05:05 PM   #15
truckdude239
truckdude239's Avatar
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
ive merged your 2 postest sionce they are askignt he same thing
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-06-2020, 01:23 AM   #16
'63GENIII
'63GENIII's Avatar
Very nice looking truck. From the few pics, also looks fairly solid. And that camper....man there's a unicorn right there. Looks like the SportsMan I have sitting in the front of the house.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-06-2020, 10:05 AM   #17
bsarts
bsarts's Avatar
I'd be all over that like a fat kid on chocolate cake.
bsarts is offline   Reply With Quote
Old 10-06-2020, 07:52 PM   #18
factorystock
factorystock's Avatar
X2! Clean unaltered originals don't come easy. Looks very similar to your GMC, does not need to be restored. Appears to have low mileage 50K? Has a rare and desirable period Sportsliner aluminum shell. 8K would be a great deal, probably would go for 15K on ebay.
factorystock is offline   Reply With Quote
