Old 10-05-2020, 04:44 AM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
No race for front outter wheel bearings??
1971 GMC 3/4 disk
Just wanna make sure I'm not missing anything. I know the inner wheel bearings have a race. The outter bearings doesn't, right??
I'm asking 'cause I'm shopping for new outter wheel bearings and I find them with and w/o the race. I don't remember anything besides the tapered outter wheel bearing falling out after removing the rotor.
Thanks.
desert-rat is offline   Reply With Quote
Old 10-05-2020, 05:11 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: No race for front outter wheel bearings??
There is a press-in race for the outers, same as the inners, but smaller, of course.
~Steven
Simi Valley, CA
Old 10-05-2020, 05:23 AM   #3
desert-rat
I don't remember anthing falling out expect the washer and wheel bearings when I removed the rotor. Was the bearing not suppose to just fall out??
Old 10-05-2020, 07:20 AM   #4
A1971Blazer
A1971Blazer's Avatar
They are two piece bearings...called cup and cone
the inner and outer race (cup) is pressed into the hub....the cone is loose and captured by the spindle nut
don't over tighten them when installing....
snug down till you feel a little turning resistance them back off about 2-3 slots in the castillated nut
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-05-2020, 10:47 AM   #5
67C10Step
67C10Step's Avatar
You won't notice the race typically as it should be covered in a good layer of grease. If you wipe around with some rags you will see the race is pressed in just like the inner bearing race but with no seal other than the dust cap.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-05-2020, 10:55 AM   #6
truckster
truckster's Avatar
The bearing will fall out, but the race is pressed in.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-16-2023, 05:40 PM   #7
ghackett1
68 C10 Longbed
ghackett1's Avatar
Inner and outers both have races. Always change races when replacing with new bearings.
ghackett1 is offline   Reply With Quote
Old 05-18-2023, 08:23 AM   #8
MARKDTN
Agree. And every new rotor I have ever bought had races installed but I have never used them. I always use the race that came with the new bearing. I like to use those (or the old race) as install tools for the new ones. I take a cutoff wheel and cut it through. Then flip that over small edge to small edge and you have a nice tool to install the new race evenly. If it is driven/pressed into the bore some it is easy to remove since it is not solid. There are tools to install races and seals but if you don't have those, this method is free.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
