fuel
![]() Join Date: Jul 2003
front shock bolts?????
ok so i have DJM upper and lower control arms, the lower ones came with the bolt for the shock to mount to, and the frame has the original bolt for the top of the shock. well the shocks are kyb gas shocks from early classics and they came with a new bolt to go into the control arm. well the shocks rubber bushing in the bottom of the shock is to small and the bolt wont go through, i have tried to press the bushing out and the rubber and the sleeve came out together. has anyone ran into this problem, or have any ideas? i hope so, thanks
chris |
GM ONLY BABY!!!
I would say to contact Early Classics personally and ask them. Mayby they accidently sent you the wrong shocks.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
![]() Join Date: Sep 2001
You have the wrong shocks. You probably have the ones for the back. The right KYB shock will fit perfectly. They did on my 3/4 ton '69 C20.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
