![]() Join Date: Jun 2007
Rare optional 3 speed overdrive trans
Found a lady selling off her deceased husbands stash of 1950's and 1960's pickup parts here in Alabama and I am going to drive over and acquire all of it in the morning. Among the interesting parts I spotted was a seldom seen original 3 speed overdrive transmission and bellhousing. the two were separated so I'll have to wait and see if they truly go together but assume so. Anyway, until I load it all up I won't know what all I am really buying, but I wanted to tell all of you about the 3 speed O.D. because that is a very highly sought after changeover trans with many enthusiasts in the 60-66 crowd.
Text me at 256 486 1988 with 60-66 parts wanted and I will check the stash and see if its among these items I am getting tomorrow or something maybe I already have
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
![]() Join Date: Aug 2020
Re: Rare optional 3 speed overdrive trans
Do you by chance have this bracket? It is the bracket that is held on by the solenoid bolt that holds the overdrive cable sheath. Thanks
![]() Join Date: Dec 2014
What’s the ratio of the top gear? Will it fit a 66 K14 Burb?
Moderator
![]() ![]() Join Date: Aug 2011
You need to post the price.
The Older Generation
You also need to check and see if it is a Tri-Five 3 speed OD transmission. They are different. They will bolt up to the later bell housings but if I remember correctly first gear is not synchronized in them. Also, a different bolt pattern on the side cover. Someone correct me if I'm wrong..... LockDoc
#6 | |
![]() ![]() ![]() Join Date: Jan 2018
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Got the trans and it is a non-synchonized 1st gear type trans with a 56 or 57 date code so will work on 60-66 but not date coded to 60-66. $250 for the trans itself - no other OD related parts were present - inquire if interested
#8 | |
LockDoc
