![]() Join Date: Sep 2020
Aftermarket doors, do they fit?
I have heard both positive and negative comments about aftermarket doors. I can't find decent ones so I ordered some from SOKY and are hoping for the best.
What has been your expeience with them if you have used them and how bad are they? Should I cancel and keep looking or are they workable? Thanks for the help. Last edited by ngnaz; 10-07-2020 at 12:57 PM. |
![]() Join Date: Feb 2010
Re: Aftermarket doors, do they fit?
Be prepared to mess with the hoops if its a 67-72 door. you will likely need a spot weld cutter, carbide cutter, and a welder. They seem to fit nicely after i played with the hoops, latches, and hinges a bit. not a good photo but this whole truck is after market panels minus 2/3rd of the cab. I have a stack of doors and every one of them has enough rust in it that i didn't want to use any part of them.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
#3 | |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
I just went through much pain with aftermarket doors for my Blazer.
I started off ordering both BLAZER doors from AMD out of Georgia (2018), which were TriPlus brand and took about 8 months to get, didn't fit well at all. My project stalled due to frustration and not knowing what to do next. Got a recommendation from a local shop that had built several C10's in the past year (2019/ 2020) and they used TRUCK doors from Truck Shop with good success. I bought one TRUCK door from Truck Shop and test fitted with the hardtop off with success. I then bought a second TRUCK door from Truck Shop and had good results. I proceeded to modify the new TRUCK doors to fit the Blazer application. The TRUCK doors sold by Truck Shop are Counterpart brand if I remember correctly. The BLAZER doors sold by Truck Shop are TriPlus brand. I learned this the hard and expensive way, hope this information helps others so they do not end up in the same situation I was in. |
