Old 10-09-2020, 02:13 AM   #1
Asshat
Asshat's Avatar
Power brake booster for single master cyl?
Did not see one of these in the Truck Shop catalog. I really don’t want to split my brake lines. Anyone else ever add a booster for a single master cylinder?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 10-09-2020, 09:10 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Power brake booster for single master cyl?
It was a factory option, you can get them still at Advance auto.
LT1 Burb is offline   Reply With Quote
Old 10-09-2020, 09:12 AM   #3
LT1 Burb
LT1 Burb's Avatar
I still have a 1 liner as my truck is bone stock.
Old 10-09-2020, 12:13 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
I gave up on single pots. When I first brought my truck home the rear wheel cylinders started leaking. I was parked facing up hill and what I didn't know was my master leaked out all the fluid. I will say I had a nice surprise when I tried to stop. Good thing no cars were coming.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-09-2020, 12:48 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
With a booster you'll want to buy capstainfabs booster bracket. Unless you can find and OEM firewall mounting plate.
I'm not sure if the bracket sold on online with the booster is the same though, maybe it is. https://shop.advanceautoparts.com/p/...rake%20booster
Old 10-09-2020, 02:05 PM   #6
roll_the_dice
roll_the_dice's Avatar
I think there was an OEM brake booster bracket for sale in the FS forum not long ago...if I remember right.
roll_the_dice is offline   Reply With Quote
Old 10-09-2020, 02:06 PM   #7
The Rocknrod
Moderator
There was the plate, it sold.
Old 10-09-2020, 08:33 PM   #8
jayoldschool
Moderator
Please split the lines. On both my 65 C10 and my mint 65 Impala, I had failures. On the truck, it lost a rear cylinder. On the Impala, the master failed and leaked so slowly between the master and the booster that there was no drip. Level got low enough until the brakes failed, and I drove right into my tire rack as I pulled back into the garage. Got really luck both times. Both now have dual masters. Fabbed my own lines on the truck, and bought the pre-fab lines so it looks factory on the Impala.
jayoldschool is offline   Reply With Quote
Old 10-09-2020, 10:54 PM   #9
AcampoDave
AcampoDave's Avatar
Two times I've had the anchor pin for the brake shoe return springs snap off the backing plate. The wheel cylnder then blew apart and it was game over. The first time I thought it was a fluke. The second time I quit the single pot stuff forever. How come you don't want to split the line Mr. Hat?
Last edited by AcampoDave; 10-11-2020 at 12:03 AM. Reason: Changed "spindle" to "backing plate" for accuracy
AcampoDave is offline   Reply With Quote
Old 10-10-2020, 01:06 AM   #10
Asshat
Asshat's Avatar
Originally Posted by AcampoDave View Post
Two times I've had the anchor pin for the brake shoe return springs snap off in the spindle. The wheel cylnder then blew apart and it was game over. The first time I thought it was a fluke. The second time I quit the single pot stuff forever. How come you don't want to split the line Mr. Hat?
You guys make a compelling point, therefore, I do believe I will convert to the dual master cylinder. It really does make sense. Thank you for your persistence.
First, I need to finish the motor and get her going.
292, 4-speed
Old 10-10-2020, 10:37 AM   #11
jayoldschool
Moderator
Good decision, happy to hear it. We'll help you with the parts and the plumbing when you're ready.
