10-09-2020, 08:30 AM | #1 |
Engine Stands
So I've gone back and forth over the years on what I'm doing for a powertrain for my 71. It originally had a 350, was gonna go LS and have since gotten rid of the motor stands that came with it. I'm back to putting a SBC in my truck and need to find some stands. Will one's from a square body work? There's a plethora of them in the pick n pull down the road from me or do I need to be on the look out for ones from a 67-72?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
10-09-2020, 08:40 AM | #2 |
Re: Engine Stands
The squares will work, it’s been done. That style of motor mount is WAY better than the previous.
As I recall there are 2 different heights of clamshells that bolt to the block. I’m not sure which one is best or if it even makes a lot of difference. The square body stands are all the same and have multiple holes for different engines. I think they’re even stamped which is for what.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
10-09-2020, 08:55 AM | #3 |
Re: Engine Stands
Here are a set on a 67 frame with a small block that I parted out . I still have them sitting in a box ready to list on the parts board . They are heavy .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-09-2020, 09:26 AM | #4 |
The Older Generation
Re: Engine Stands
I think the frame has to be notched a little bit where they sit. Maybe 3/8ths of an inch or so. LockDoc
10-09-2020, 10:38 AM | #5 |
Re: Engine Stands
Thanks guys! I'll keep an eye out, Grumppy I'm sending you a PM.
