This bulb is smarter than me
I feel like an idiot. Shouldn’t this tail light bulb just push in, twist and come out? I’m pushing but it doesn’t want to turn nor eject. Please and thank you.
![]() ![]() ![]() Join Date: Jan 2018
Re: This bulb is smarter than me
Yes, it should push in and turn. Sometimes, I feel like I pushed mine far enough in, but it wasn't and needed a little more shove
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Active Member
![]() Join Date: May 2019
Wrap it in a rag first. Work it. Wiggle it. Just a little bit. It may come out. Seriously, be careful! I once sliced opened the end of my thumb when the glass crumbled because I was trying to do what you are doing. I can show you the scar. If it wont move then very carefully break the glass (Or pull off the bulb from the base) and use a needle nose or duck bill pliers to push in, twist, and pull out the brass bulb base. I always use dielectric grease or silicone paste when installing the new bulb. Its an old trick and for sure it wont get stuck again. You don't need much, just a light coat. Good luck!
#5 | |
Who Changed This?
![]() Join Date: Jan 2013
Moderator
![]() Join Date: Dec 2012
If the bulb is bad already, smash it, clear out the glass, then push/turn the brass with needle nose pliers.
This is what I would do. It's possible someone put the wrong bulb in and it's really stuck in there. Get the glass out of the way, then you can bend the metal inward if needed to free it up.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
