10-12-2020, 04:06 PM | #1 |
Motorhome radiator?
I pulled a 454 from a motorhome to put in my new project.im wondering if anyone knows if a radiator from an 80s bounder motorhome fits in a GMC 3500?I'd like to use it because it has the oil cooler and trans cooler built into it.
10-12-2020, 11:32 PM | #2 |
Re: Motorhome radiator?
I would measure the width as being a Chevy I wouldn't be surprised if it worked. Depending on the combo your truck started with. You may need to move a few things around. I put a HD 454/Diesel radiator in a C10 I had 20 years ago. It took a bit to make enough room, and if I had it to do over. I would of grabbed the OG core support.
My C10 had a stock warmed up 350, and the electric fans barely came on at idle. Litterly if I let it idle for 15 minutes after reaching temp. Then it would finally turn the fans on. |
10-13-2020, 12:10 AM | #3 | |
I was just curious if someone might have used one before. |
10-13-2020, 10:39 AM | #4 |
The dimension you need is width and height.
Compare those. Wider works easier than height for fitment. Thickness (number of tubes) usually easy to fit. |
10-13-2020, 11:05 AM | #5 |
10-13-2020, 07:25 PM | #6 |
Just here to tinker
My '78 diesel came original with oil cooler and trans. cooler in the radiator tanks. So its possible.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
10-13-2020, 07:30 PM | #7 |
Just here to tinker
10-13-2020, 07:58 PM | #8 |
