Old 10-12-2020, 08:53 PM   #1
Seth2789
Motor swap
Hey guys,
This is my first time swapping an engine and need some advice. I bought the mounts from some fab store off ebay. My question is that the motor looks like it's sitting very unlevel. I've looked all over the internet and cannot get a straight answer. Look at my pictures and tell me what you think! Any advice would be greatly appreciated!
Seth2789 is offline   Reply With Quote
Old 10-12-2020, 08:56 PM   #2
geezer#99
geezer#99's Avatar
Re: Motor swap
Where’s the pics?
Old 10-12-2020, 09:01 PM   #3
Seth2789
Re: Motor swap
Check it out!
Old 10-12-2020, 09:15 PM   #4
HO455
Post Whore
HO455's Avatar
Re: Motor swap
Which direction are you concerned about side to side or forward to aft? Engines in our trucks always have the front of the engine higher than the back.
RIP Bob Parks.
Old 10-12-2020, 09:21 PM   #5
Seth2789
Re: Motor swap
Front to rear. It just seems like it's sitting very high in the front.
Old 10-12-2020, 09:21 PM   #6
geezer#99
geezer#99's Avatar
Re: Motor swap
That’s normal.
Carbed motors sit down at the back. About a 4 to 6 degree slope.
Carb intakes are made so the carb sits level.
Fuel injected motors also sit like that.
Not as critical.
Down in back gives lower trans tunnel needs as well as driveshaft angle not as severe.
Put an angle finder on the tailshaft to see what it is.
Old 10-13-2020, 12:34 AM   #7
kwmech
Re: Motor swap
To me, it looks like the nose of the crank is sitting too high in relation to the engine in my truck. Wonder where the center of the water pump will be with the radiator
Old 10-13-2020, 10:03 AM   #8
AU Doc
Re: Motor swap
Looks like it needs the trans mount on it to know for sure what the angle will be. Once you have a trans mount, then put an angle finder on it.
AU Doc is offline   Reply With Quote
Old 10-13-2020, 10:23 AM   #9
68 P.O.S.
Re: Motor swap
Also looks like your upper A-arms are on the wrong sides.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-13-2020, 01:06 PM   #10
kwmech
Re: Motor swap
Good catch on the A arms. Looking close at the pics it appears his center link is in backwards also
Old 10-13-2020, 01:44 PM   #11
68 P.O.S.
Re: Motor swap
I can't tell for sure, but you may be right on that centerlink
Old 10-13-2020, 09:05 PM   #12
Seth2789
Re: Motor swap
Man thanks so much for catching that. This is my first rebuild ever and I've learned a lot. Man I feel stupid for messing that up!
Old 10-13-2020, 09:09 PM   #13
Seth2789
Re: Motor swap
Do the lower ones look right?
Old 10-13-2020, 09:09 PM   #14
garyd1961
Re: Motor swap
Don't feel bad you certainly ain't the first one to do it.
garyd1961 is offline   Reply With Quote
Old 10-13-2020, 09:12 PM   #15
Seth2789
Re: Motor swap
The lower ones have to be right because of the shocks. What about the centerlink?
Old 10-14-2020, 01:41 AM   #16
kwmech
Re: Motor swap
The tie rods have to come from the back so the castle nuts are forward. Meaning that the center part needs to be swapped from pitman to idler so the tapers come in from the rear
Old 10-14-2020, 11:10 AM   #17
68 P.O.S.
Re: Motor swap
No reason for you to feel stupid, it happens to ALL of us Yes, your lower arms are on there correctly, but the uppers need to be switched. I can't really tell on the centerlink tho, can you take a couple close pics showing the orientation? kwmech is correct on the tie rods mounting location. I like the engine btw, looks good
Old 10-14-2020, 12:29 PM   #18
Richard2112
Richard2112's Avatar
Re: Motor swap
Originally Posted by geezer#99 View Post
That’s normal.
Not as critical.
This^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Pay special attention to your drive line angle.
Richard2112 is offline   Reply With Quote
Old 10-14-2020, 01:27 PM   #19
bry593
Re: Motor swap
That’s normal.
Nominal GM tilt is 3 degrees. Some may have more, some less, but the pad on a q-jet intake is machined at 3 degrees.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 10-15-2020, 01:18 PM   #20
j_cst_10
j_cst_10's Avatar
Re: Motor swap
Good advice so far. Put the trans mount in and then put an angle finder on it. Roughly between 3-5 degree. You can put shims under the transmission mount to lessen the angle if it comes out more severe once you measure it.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 10-15-2020, 01:30 PM   #21
AU Doc
Re: Motor swap
Agreed.
Some swap kits will tilt everything down more in order for the trans to clear the floorpan. Then leave you with the headache of working out driveline angles. I'm still working on my first C10 build, so I have no idea how much space there is to work with, but keep in mind there may be a limit to how much you can shim the trans up without hitting the floor pan (of course there also may be miles of room, I honestly don't know). Just something to consider if the cab isn't on the frame.
