Old 10-13-2020, 10:01 AM   #1
Don Brace
Active Member
MN 700R4 cross member
I am installing a 700r4 behind a 350 in my 71 Longhorn. What cross member do I use? The holes in the cross member in the truck do not line up. It has the stands on the bottom of the cross member. Do I just drill new holes?
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 10-14-2020, 10:31 PM   #2
tdangle
tdangle's Avatar
Re: nn 70r4 cross member
That is probably the easiest way to do it. surprised it doesn't line up with any of the existing holes. When I went from a TH350 to a 2004R even though they are the same length, the mount is in a different location, so I just moved the crossmember to the other set of holes,
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-14-2020, 10:46 PM   #3
geezer#99
geezer#99's Avatar
You know Terry, I think he’s describing his factory bell housing mount crossmember. He mentions the stands on the bottom of the crossmember.
Maybe he doesn’t know that that crossmember needs to be removed to install an automatic trans. And a crossmember at the tailshaft installed.
That’s kinda how I read it.
Old 10-15-2020, 08:02 AM   #4
Don Brace
Active Member
Thanks for the replies guys. I do have a cross member under the 700r4. Only two holes line up. One on either side where the cross member meets the frame on the top of the frame.
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 10-15-2020, 09:00 AM   #5
geezer#99
geezer#99's Avatar
That’s normal.
Whip out the drill and make some holes.
Old 10-15-2020, 09:13 AM   #6
Don Brace
Active Member
That is my plan
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
