![]() Join Date: Jul 2015
Exhaust header recommendation + question
Looking to install some headers when I get the motor back in, so I was looking for suggestions. I have seen the Flowtech and Hooker long tube headers, however, I am wondering if they will work with the manual trans. The clutch linkage is near the exhaust.
Also, when using headers on a straight six, you need to run coolant lines to the intake manifold, correct? This is to keep the intake warm?
1963 C20, small window, long bed 292, 4-speed |
Re: Exhaust header recommendation + question
I did some more searching, looks like this is a good one.
https://www.12bolt.com/store/p153/Ex...-250-292_.html
Moderator
![]() ![]() Join Date: Aug 2011
Oh ya, those are cool.
![]() ![]() ![]() Join Date: Jan 2018
That's probably what I would go with if I was putting a 292 in my truck
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Wow, those look like a nice part. More nostalgic than tublular headers which is a good thing. Yes the coolant lines are to keep the intake warm.
#6 | |
Moderator
I had those headers on my 65. Installed by the Previous owner hb32.
They fit nice and were super quiet. I used a heat plate to run coolant thru to warm up the intake plenum. |
