10-15-2020, 07:51 AM | #1 |
4L60E column shift linkage
Getting set to connect my column shift to the 4L60E transmission.
I have two Heim rod ends and a piece of 3/8 rod I see that several people are using the Lokar kit with the adjustable bracket that attaches to the transmission. I am planning on machining my own to go there. The column has about 54º of travel from Park to L1....the bracket on the transmission has about 78º from Park to L1 My question(s): About how far (radius) is the centerline of the rod connection from the actuator stub shaft coming out of the transmission? I can slot the piece I make for adjustment, but I'd rather get it right to begin with. Also about what angle is the bracket set to in the Park position? I think it would need to be just a few degrees downward in order to let the shifter move more easily out of the Park position and still allow full range of all the gear positions without binding. I can figure all of this out but I'm hoping for a head start and some time savings...Thanks!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 10-15-2020 at 09:40 AM. |
10-15-2020, 09:01 AM | #2 |
Post Whore
Re: 4L60E column shift linkage
I'm confident you can figure it out....
But I would have to cheat and make a slotted one to find the perfect location...then make the real one based off the slotted one... with 24° diff in travel it would make it easier on me... The one on my trans is approx 2-1/4" from the trans shifter center to the pin center where the shifter cable hook up..... In park, the lever hangs down at about the 7oclock position ...the shifter cable comes from the rear..and pulls the lever backwards.. Does your trans not have the lever on it?..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-15-2020 at 09:12 AM. |
10-15-2020, 09:38 AM | #3 | |
I was looking at just a rod directly from the shifter lever down to the transmission lever. Searching the forum results in several that are connected this way using the Lokar rod kit. My original plan was to just slot the lever...(similar to the Lokar) then use a bolt thru the slot.....get it adjusted and tack weld it in the proper location
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-15-2020, 08:55 PM | #4 |
If you need a photo with a scale LMK I used the Lokar ends on mine and made a longer rod for the 700R4....engine is mounted 3" back. also added a bend for clearance.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
10-16-2020, 07:21 AM | #5 | |
I cut the ball off of the lever that was on the transmission, then bent a 3/8 rod to go from the column down to a heim joint. After a couple of adjustments to the bends, I was able to get it to shift, but the lever radius is too small to allow it to go much past drive without binding. A measurement of the radius and the approximate angle of your lever at the transmission would help..... and be much appreciated.
10-16-2020, 12:10 PM | #6 |
Tough to get a decent photo, need 2 more thumbs.....bend from the top is about 5" down.....getting an angle from the bottom, I will look for my angle gauge.
10-16-2020, 12:14 PM | #7 |
Looks like 2 1/4" -2 3/8"...on my adjustment slot....you might need more.
10-16-2020, 12:19 PM | #8 | |
I will slot mine for adjustment Also yours looks almost horizontal or slightly downward with the transmission...that's what I was most concerned about.....the stock one is down about 15º and that makes it bind if I try to go past drive. Does your indicator line up properly?
10-16-2020, 12:56 PM | #9 | |
10-16-2020, 07:38 PM | #10 |
I started with a home made cable linkage and honestly it was not doable for me. So to my surprise I went and got a factory assembly and with moving the position of the bracket and extending the rod It works perfectly. I would have never guessed it would work like it does.
10-18-2020, 05:01 PM | #11 |
i used the stock linakge on my 71 with 4.8 4l60e
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-19-2020, 08:48 AM | #12 |
I machined a new adjustable lever for the transmission....changed the angle to about 5º down and slotted it for some adjustment.
It will shift to all positions but the indicator doesn't line up at each one. In Drive it's perfect....I'm going to leave as is for now and tweak it when I do the final assembly
10-19-2020, 10:30 AM | #13 |
You likely won't get the detents to line up perfectly unless you modify them since the column is made for only a 3 speed transmission. Modifying the detents can be done though, but takes some time. If you have a tilt column, then you have to disassemble the column to get to them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-19-2020, 10:48 AM | #14 | |
Although they got closer, still did not align exactly. Park and Drive are perfect...I suppose that's going to be sufficient. Thanks!
10-19-2020, 11:11 AM | #15 | |
That is a nice lever you made, is it steel or aluminum?
10-19-2020, 11:15 AM | #16 | |
I was thinking that when I got it adjusted as best I could, I would make one out of stainless...but probably not necessary.
