Old 10-15-2020, 11:55 AM   #1
Scott2.0
Fuel filter leak?
Sorry for the ignorance, guys. Is this my fuel filter? It’s leaking like mad. Couldn’t figure out why I was dying from fumes on last night’s cruise and this morning’s puddle clued me in.
Scott2.0 is offline   Reply With Quote
Old 10-15-2020, 01:05 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fuel filter leak?
That's an aftermarket filter that should be addressed. Never seen one like that though so I can't be of technical help there.
Old 10-15-2020, 05:29 PM   #3
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
That appears to be a fuel filter (not stock, I think), and it shouldn't be on the suction side of the pump unless it was the factory one, which is pretty big, IIRC. I'd just take it out and replace the flex line while I was in there. There should be a filter in the carburetor, unless you have an Edelbrock (I suspect this because that other item appears to be a pressure regulator).
~Steven
Simi Valley, CA
Old 10-15-2020, 06:35 PM   #4
Scott2.0
Thanks! Carb’s a Holley. You think just do away with the filter?
Old 10-15-2020, 06:51 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
Replace with a one piece filter. Please don't use the 3 piece glass filter from your favorite auto parts store. They are fire starters. Just get a regular one-piece plastic unit and call it a day.
Old 10-15-2020, 06:54 PM   #6
Scott2.0
How’s this one? Only got it because it’s coming same day.
WIX Filters - 33003 Fuel (Complete In-Line) Filter, Pack of 1 https://www.amazon.com/dp/B000CSEUPG..._ulnIFbX8Q5SQA
Old 10-15-2020, 07:39 PM   #7
Steeveedee
Steeveedee's Avatar
I had one of those glass three-piece jobs that Corts60 mentioned on a car once, and it started leaking. Tossed it and put on a metal can type. This filter should be fine if there is no filter in the carburetor, and even then it should be fine. Put it on the line between the pump and the carb, though, and just lose that whole plumber's nightmare.
~Steven
Simi Valley, CA
Old 10-16-2020, 11:44 PM   #8
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Being All The Engine Heat Not Helping Matters Aluminum Attracts the heat Get a Clear Plastic one put in Front of Engine with fan Air
1963 Impala
2021 Harley Road Glide
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2006 Silverado 1500
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 10-16-2020, 11:45 PM   #9
1971 GMC SHORTY
Being All The Engine Heat Not Helping Matters Aluminum Attracts the heat Get a Clear Plastic one put in Front of Engine with fan Air Hitting it
1963 Impala
2002 FXDP
2006 Silverado 1500
