10-16-2020, 10:41 AM | #1 |
1965 Chevy C10, 2005 4.8L/4l60
Drill and tap the head for stock 65 temp sender?
Anyone did this? Info please
Posted via Mobile Device |
10-16-2020, 12:06 PM | #2 |
Post Whore
Re: Drill and tap the head for stock 65 temp sender?
Yep...I've done that to all mine...I've done both 3/8 & 1/2 npt...
3/8 npt was for a elec sender ,,the 1/2 npt was for a mech sender... I'm not sure what size your 65 has... i drill and tap the pass side head at the rear I remove the plug that's there...I've done them in the truck, but prefer to do it on a engine stand...that way i can tilt the engine at a angle...after drilling i take a shop vac and stick over the hole to suck out any stray shavings...then on the tap i put grease in the flutes to catch the tap shavings...
10-16-2020, 09:26 PM | #3 |
60-66 Nut
10-16-2020, 11:08 PM | #4 |
Post Whore
I looked for that post Capt... and couldn't find it...
10-17-2020, 09:26 PM | #5 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-19-2020, 08:15 PM | #6 |
60-66 Nut
So the LS heads have a hole smaller than 3/8" NPT?
10-19-2020, 09:31 PM | #7 |
Yeah it is smaller. If you are running aftermarket gauges like Autometer they can supply a brass adapter that screws in the stock LS port on the cylinder head. Works well.
On some my older LS swaps I did drill and tap the head. The only thing I would add to above is put some grease on the drill bit to catch the drill shavings. Also as you tap the new drilled hole, tap it a bit and check with the sensor if it's deep enough. Kind of sneak up on the depth of the threads since it's pipe threads. |
10-20-2020, 07:15 AM | #8 |
I have been doing the modification of the factory sender for the 67-72
The stock sender is ½-NPT and there is enough material to turn and thread it to ⅜-NPT Unfortunately the LS style sender is 12mm and there just isn't material enough to machine it down that small Here is a cut away of the stock sender
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-25-2020, 07:28 PM | #9 |
I'm a little late getting here but has anyone tried the Classic Instruments SN12MM
It's supposed to be a 12mm sender that will work with older gauges. |
