Old 12-16-2003, 01:14 AM   #1
76bonanza
76bonanza's Avatar
Summit cast Alum tranny pan
Has any one installed one? It came with two complete sets of bolts one like reg. bolts and one like 13 point bolts or somthing like that witch one is better?
Also is that cork gasget good enuf? Very nice pan by the way very thick.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-16-2003, 01:26 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
There are 6 point and 12 point bolts as to witch is better I would be able to say. Cork is fine just don't over tighten the bolts. I would also be careful with the pan around rocks and things like that if you 4x4. Aluminum tends to crack and break where metal will cave in and forum to the object. Something to think about if you go off road and stuff like that. Other than that aluminum pans are nice to have.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
