10-19-2020, 08:48 PM | #1 |
Door bolts
How do you replace the threaded plate inside the front pillar?
10-20-2020, 07:34 AM | #2 |
Moderator
Re: Door bolts
Cut sheetmetal.
10-20-2020, 08:45 PM | #3 |
Re: Door bolts
Yeah, I’m thinking you’ll have to get a cutting wheel and open them up that way. I’m guessing one of yours is stripped out?
10-21-2020, 08:53 PM | #4 |
Re: Door bolts
10-25-2020, 09:56 AM | #5 |
Re: Door bolts
Cut the A pillar open, fix the plate and then reweld it back together.
10-25-2020, 11:17 AM | #6 |
Re: Door bolts
One of my lower ones fell down also. If I remember correctly I think I used a flexible magnet to fish it up and then used a 90 degree pick to hold in place ant then used some small wire looped thru the bolt holes until I got one bolt started and then cut the wire. Good luck.
