Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-20-2020, 05:52 PM   #1
CARZ1968
Bowties from Birth
CARZ1968's Avatar
3inch exhaust reduced?
My 99 c2500 came with 3inch exhaust to the muffler then it reduced to a single 3 inch exhaust. would switching to a dual 3inch outlet with dual 3 inch turndowns give me the best gas mileage/ performance? Should I add reduced turn downs (2.5 inch) instead of the 3"s? Looking to add a cold air kit, performance mass air flow and a program in the future.
68 K10 Burb aka "da bomb"
72 C10 SWB Highlander
97 30th anniv. Z28 Conv
99 Chevy Crew 454
11 Traverse AWD
CARZ1968 is offline   Reply With Quote
Old 10-22-2020, 08:33 PM   #2
HAULIN' IT
Re: 3inch exhaust reduced?
The short answer would be: It would only help if the single 3" muffler guts/tail pipe are the restriction. If they aren't, you gain nothing.
Spending some time figuring/measuring the inside tubes & opening inside the muffler can be REAL eye opening! Quite often, the manufactures (even BIG well known companies) do all sorts of "cheats" where they use say, a 2 1/2" core in a whole group of mufflers & change just the ends that you see/attach to the pipes...not a problem for a guy with 2 1/4" exhaust or even 2 1/2", but if the engine really needs a 3" & the muffler has a 2 1/2" core area...pipes mean nothing at this point.
You would have to have a pretty nasty engine to need dual 3" exhaust. Also if you do, the words "gas mileage" wouldn't be something you would type very often. I guess I'll leave it at that. Lorne
HAULIN' IT is offline   Reply With Quote
Old 10-25-2020, 09:22 AM   #3
b454rat
I had a similar truck like urs, had the dual 3" into the mufflers. Actually it had dual flow's on it, but i did true duals with i think 2 1/2" into the muffler, then dual 3" out the back. I don't think I gained anything, other than a good sounding exhaust.
Old 10-25-2020, 04:59 PM   #4
LS short box
I like to run 3" from the headers to a 3" muffler inlet. Then 2.5" tail pipes if room is limited. If you have the room I'd go 3" all the way.
I would go with an aftermarket mandrel kit or build it out of mandrel bend pieces. Muffler shop tubing benders really squish 3" tubing when they bend it.
LS short box is offline   Reply With Quote
