10-24-2020, 01:13 AM | #1 |
Lower AC bracket configuration - 350, is this correct?
I purchased a set of used brackets for the AC compressor - 350 for use in my -69. Mocking this up something isn’t right or missing parts. This lower bracket will not fit against the exhaust manifold without some kind of spacers between the bracket and the manifold. Is this correct? This is a factory 69 exhaust manifold but I think all of my brackets are 70-72. I think I remember reading somewhere that 69 small block brackets for the air conditioning are one year only? Any thoughts on what should be correct here or if I have a compatibility issue?
In the picture below you can see I put a silver spacer between the bracket and the exhaust manifold and the bracket still hits the exhaust toward the left. Steve weim55 Colorado Last edited by weim55; 10-24-2020 at 01:47 AM. |
10-24-2020, 08:13 AM | #2 |
Carpe manana
Re: Lower AC bracket configuration - 350, is this correct?
There’s a special manifold stud that secures both the manifold and the bracket to the head. It’s reproduced.
Edit: Here’s an example - https://www.zip-corvette.com/64-76-3...cket-stud.html
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 10-24-2020 at 08:16 AM. Reason: Added |
10-24-2020, 09:17 AM | #3 |
OK! The illustration from the Corvette catalog is super helpful! The pieces I have appear to be the same as the ones illustrated. Had no idea the Corvette brackets would be the same on our trucks. I’ll pick up one of those manifold studs.
Steve weim55 Colorado |
