![]() Join Date: Feb 2001
LED's?
This week I will install all LED's in my 04.
Have any of you installed LED's? Your thoughts.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: LED's?
I haven't historically been huge fan of LED headlights, but also haven't used them in years so take that with a big grain of salt. I am sure they've gotten better.
What I do is swap from 9005/9006 to 9011/9012. Its a simple procedure, get OEM bulb longevity, and significant more light output, without the extra glare/back scatter. You've not nice clear lenses, so you'll have an even better effect regardless of what bulb you go with. I've heard newer style LED headlights are "directional" of sorts - to provide a clean cutoff line and more output down the road, but I haven't tried them in years. Interested to see what the outcome is! EDIT: apparently I can't read. I usually do LED's all over my interior, my reverse lights, maybe tail/brake lights, but thats it. Last edited by skyphix; 10-26-2020 at 09:37 AM. |
![]() Join Date: Feb 2000
Re: LED's?
In my '02 I had LEDs in the dash, HVAC/Radio, dome lights, mirror lights, license plate, reverse lights and DRL's. I never bothered with the headlights- I felt the halogens were good enough and I got others flashing theirs at me enough just using Sylvania bulbs.
Diode Dynamics makes some real nice LED's, US made too. https://www.diodedynamics.com/by-veh...sid=yjSXGn7rQg
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Re: LED's?
My 01 has LED for the day time running lights with no problems (2 years) I know the standard ones were prone to burn out a lot
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#5 | |
Re: LED's?
The LED's have come a long way ....
#6 | |
Re: LED's?
everything works except the radio head unit, couple of backlights out but half the buttons are broken and ready to fall out anyways.. I just listen to k-earth so volume knob is all I really use.. really can't recall replacing any other bulbs except these.. I just left them out the third time ![]()
I started out with nothing - and I still have most of it |
Re: LED's?
I have installed in my 02 suburban, huge difference and now i can see at night. You will be extremely satisfied, only thing left are my fog lights. Do you have daytime running lamps? if so what #bulb do you use.
Mick 1972 C20 Deluxe ![]() MADE IN the U.S.A. |
Re: LED's?
These
Moderator
![]() Join Date: Oct 2008
Re: LED's?
I have Sylvania Zevo 194 LED bulbs in the side marker lamp positions on my truck along with 194s & a Festoon bulb in the interior.
Be careful of the taillamps and the front parking/turn & DRL lamps. You can have issues with phantom current draw with LED bulbs on some vehicles. The Epsilon II Impala can not have LED bulbs installed in the backup, marker, and turnsignal bulb positions at the front and rear... Not sure about the markers. The battery runs down overnight. There's a bug in the BCM bulb check software that keeps the vehicle systems from going to sleep with LED bulbs in those positions. GM isn't the only one affected by this behavior. I've read about Nissan, Honda, Subaru, Volvo, and Toyota vehicles that do the same thing. You can flip the bulb check bits off in the VW, Audi, Seat, & Skoda BCMs so they don't do this crap but if you forget to do that it'll bite you on those too. New headlamp housings and Sylvania Xtravision or Phillips 60% Vision bulbs will give you real nice forward lighting. LED bulbs are sexy but you can replace the 9005 HB4 bulbs with 9011 H1R and the 9006 HB4 bulbs with 9012 H1R bulbs. You have to trim one of the locking tabs slightly to mate with the housings but otherwise they fit just fine. They're the same wattage so they don't melt the housings. If you take care to adjust the headlamps properly you will not get flashed by oncoming traffic.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-26-2020 at 04:05 PM. |
#10 | |
Re: LED's?
Re: LED's?
Yep got 9005s for hi and low beams. Also led parklight and DRLs. Installed a led flasher so no need for resistors. Also did the hi 6 mod chip. Let's my low beams and fog light be on with the hi beam. Also led license plates lights.
https://youtu.be/vCN3ZhRjORU https://youtu.be/zIwVqV3PQps
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
Re: LED's?
Why is your plate like that and your bumper is all shorts of crooked.
#13 | |
Re: LED's?
The truck is sitting on uneven ground ... 1/2 on the driveway and 1/2 on the grass.
#14 |
Re: LED's?
On ok looks like its messed up in the picture. I know mine is not strait.
#15 |
Moderator
Re: LED's?
Parallax is a displacement or difference in the apparent position of an object viewed along two different lines of sight.
The two different pictures in this thread are a case study in Parallax issues with cell phone cameras. The CCD is much better in newer phones so the resolution doesn't suffer, like it did a decade ago, but the tiny lens with no mirrors gives rise to Parallax errors.
And please let us know if and how your repairs were successful. |
| Bookmarks |
