Old 10-26-2020, 12:00 PM   #1
mick53
Airbrushing auto paint and primer.
I'm getting ready to paint my transmission (TKO 600). I'm using TCP Global Firethorn Red Pearl urethane paint. https://tcpglobal.com/products/kus-k...IaAoMYEALw_wcB
I have a very nice airbrush with all the tips. I also have a Fuji 5 stage turbine spray rig with touch up gun and multiple tips. This transmission has a lot different angles that need painted. I'm concerned that with a gun by the time I get coverage I will have too much paint on spots and it will run. Can I use an airbrush and is it practical? I have the little jars for the airbrush. This is a base and clearcoat system. Thank you for your time.
mick53 is offline   Reply With Quote
Old 10-26-2020, 12:30 PM   #2
mr48chev
mr48chev's Avatar
Re: Airbrushing auto paint and primer.
I always thought aluminum pieces should stay aluminum unless you are trying to hide a billet piece like an accessory bracket on a traditional build.
To paint it I'd say it is more of a case of use what you are most comfortable with and what you feel you have the most control over, Probably the air brush for getting in all the nooks and crannies.
My ongoing truck projects:
Old 10-26-2020, 01:46 PM   #3
mick53
I'm not that comfortable with either unit. I've never used the turbine. I was proud of myself for resisting polishing it. Would I need to thin it out more than usual with the airbrush? Is that done with the reducer? I have very little experience in the auto paint area. I'm hoping to hone my skills on stuff like this.
Old 10-26-2020, 03:57 PM   #4
sack54
mix paint the same as spray gun, then add a little more thinner(Reducer) as need, Just want it to spray like a spray can of paint.Practice on some cardboard or old clean metal. very easy to control.
Remember light coats to start
sack54 is offline   Reply With Quote
Old 10-26-2020, 09:08 PM   #5
1project2many
I've used automotive paint in an airbrush. I'm not a pro and I'm not an artist. I painted the body of a model truck with the same paint on my truck and I've painted portions of the dash and some interior pieces inside my truck. I started with recommended mix then added thinner in order to get the pattern and coverage I wanted at a low pressure. The model truck was a bit fun because I had the air regulator set at about 20 psi when I figured out the mix and brush settings by spraying test shots at a junk fender. I turned around to spray the body and ended up blowing it about a foot away. Whoops! Lower pressure and try again.
1project2many is offline   Reply With Quote
Old 10-28-2020, 10:04 AM   #6
my56chevytruck
my56chevytruck's Avatar
glad you've asked the question about airbrushing, I too am wanting to use mine but I've only used an Eastwood paint gun to paint with. You can use your paint gun with the right tip. Maybe use the tip of 1.2 to 1.4 with lowering your pressure and reducing the amount of paint thru the gun? you won't want to cover the tranny with one coat anyway. A little at a time.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-28-2020, 11:54 AM   #7
_Ogre
_Ogre's Avatar
i think your setting yourself up for heartbreak trying to paint a transmission
short of total disassembly and baking the case, i'm not sure how you'd get the oil out
realistically; unless your one of those guys that parks on mirrors at shows, who's gonna see it?
shop air compressor timer
Old 10-29-2020, 07:52 AM   #8
FAKKY
Is that real ? Or a saying.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 10-29-2020, 09:29 AM   #9
my56chevytruck
Ogre's correct, why not simply clean the tranny case and let the aluminum show itself. Save yourself from work you could be doing elsewhere!! My .02 worth
1940 Ford Dlx Coupe
1969 Mach1
Old 10-29-2020, 10:18 AM   #10
1project2many
Have you seen the build? It's not likely to drive like a stocker. Just imagine an angry bear rearing up on it's back legs.
Old 10-29-2020, 10:31 AM   #11
layinrocker65
layinrocker65's Avatar
He really needs to have a build thread. Amazing work going on with the truck.
As far as the original question, I have no input but look forward to the results.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 10-29-2020, 11:05 AM   #12
FAKKY
Whoa.
Just saw a thread ........ yep ... now I get why he's looking to paint.
Going to be hard to get the oil out ....... so adhesion good underheat etc .... but its been done
Old 10-29-2020, 12:43 PM   #13
mick53
It's a brand new tranny so never been dirty. I know not many will see it but I'm the kind of guy that polishes places on parts nobody will ever see except that one guy. I'm going to have to look at it for probably a couple more years. The fact that it's not in your face gives me something constructive to build my skill set on. Kinda like my welding and machine work. Pluss the pictures will look better in the process so really I'm doing it for you folks.
Old 11-02-2020, 09:53 AM   #14
Kevin Mac
Kevin Mac's Avatar
Look into self etching primer for aluminum, it does help.
Mac
Kevin Mac is offline   Reply With Quote
Old 11-02-2020, 01:46 PM   #15
notsolo
notsolo's Avatar
I have not seen the Fiji, turbine, but that sounds very promising...touch up gun would be good choice also. Many Youtube clips on painting, I still box my paint....add reducer and pour from 1 cup to another.....practice with it and get your work piece at a good level...hang it if you can. .....some of the TCP Global bright colors work best with a light base coat of silver....I used the TCP...UMB.....on my Blazer, complete color coat of silver then 3 coats of lime, 5 coats of clear.
notsolo is offline   Reply With Quote
Old 11-02-2020, 06:54 PM   #16
mick53
I bought the turbine because I live in Indiana and getting the compressed air dry enough to work well is very expensive. Also the Fuji is portable and uses 9.5 PSI so little overspray and stirring up dust. I don't have a booth. I was going to use 2K epoxy but I have self etching also. If self etching is too thick or too soon are there acid residue problems?
Old 11-02-2020, 07:06 PM   #17
notsolo
notsolo's Avatar
Not the expert on primers...I like epoxy, but don't know what's best on aluminum. Probably not an option, but if the Firethorn was over super clean alumium. It probably would look good....durability is in question without a primer....might research phosphoric acid on aluminum as a prep....Others use urethane as engine paint to match colors....again don't know if primer is required.
Old 11-12-2020, 11:42 AM   #18
gigamanx
This is totally for real. I've seen it at many of the larger swap meets and car shows. Usually in the invitational car corral. I've seen it with some of the lifted bro-trucks too so they can show off their aluminum undercarriage. Like you can't see under an 8ft lifted truck :/
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 11-12-2020, 01:25 PM   #19
_Ogre
_Ogre's Avatar
makes me wanna barf
anything that clean is never driven
not driving a classic car, to save it for posterity
is like not having sex with your wife, saving her for the next guy
Old 11-13-2020, 11:29 AM   #20
Rickysnickers
Rickysnickers's Avatar
makes me wanna barf
Well now, that's an interesting way of looking at things.
Old 11-13-2020, 10:12 PM   #21
_Ogre
_Ogre's Avatar
a better way to look at it is 36,000 miles on truk since i rebuilt it 10 years ago
probably 30,000 the 1st 5 yrs while i was younger and able
Old 11-20-2020, 10:57 AM   #22
my56chevytruck
makes me wanna barf
You go Ogre, I have a street rod that I've put a lot of money into, for cruisin and car shows. I've been asked multiple times, YOU DRIVE THAT? My answer is that is why tires were invented. Never once has it been trailered to a show. It's nice to see the work and detail that people put into their rides, but enjoy it, drive it, and have fun cleaning it.
1940 Ford Dlx Coupe
1969 Mach1
Old 11-20-2020, 02:05 PM   #23
mick53
I figure it's good practice for me plus I have to look at it for at least another year, probably 2 or 3. Also if I put it on it's top what would people think? How embarrassing would that be?
Old 11-24-2020, 04:42 PM   #24
_Ogre
_Ogre's Avatar
sort of like your mom telling you to put clean underwear on, in case you end up in the emergency room
i put my 1st 58 on it's top when i was a teenager, not much soft stuff to land on in our trucks
Old 11-24-2020, 11:17 PM   #25
mick53
That's just plain funny.
