12-16-2003, 01:30 PM | #1 |
gas tank woe's
I plan on relocating the gas tank on my 72 3/4 ton 4X4 from behind my seat to elsewhere. But my bed sides already have good paint on them and i don't want to cut them for a gas door. I will haul a lot of crap in the bed, so i don't really want the gas cap in the bed floor (due to the fact that i don't want a bunch of stuff getting into my gas tank). Should i mount one in the bed of the truck, or try the whole marker light filler thing? For the marker light idea, where do you get the filler hose and how hard is it to route it between the inner and and outer bed side.
Thanks for any help David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
12-16-2003, 01:42 PM | #2 |
Mike
Try this http://www.classicheartbeat.com/mark...t_gas_door.htm You can get the hose at napa or other parts places.You can do like in the article,or you can get a muffler adapter to hook together the two different size hoses.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
12-16-2003, 01:53 PM | #3 |
THanks Smokekiki
That is just what i was needing, do you know if putting a tank under the bad is a tough job?
12-16-2003, 04:09 PM | #4 |
Try Here and Here for the FAQ'x on tank install and Tennman's side marker fuel door. Hope this helps!!1
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
12-16-2003, 06:46 PM | #5 |
Thanks jorgensensc
I was gone to Kentucky over halloween and must have missed your post. Nice detail, that must have taken forever to type up Thanks again (got it bookmarked) David
12-16-2003, 07:30 PM | #6 |
FUEL CELL GURU
Another option....
12-16-2003, 07:49 PM | #7 |
Fuelcell guy, i pm'ed you.
12-17-2003, 12:10 AM | #8 |
Back from the Dead
I used a filler setup from a 69-72 Blazer tank for my truck. It stays out of the way and just had to cut a small hole in the bed floor.
heres a pic... Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
12-17-2003, 12:37 AM | #9 |
FUEL CELL GURU
Nice....
I like that one too.
12-17-2003, 12:43 AM | #10 |
Without stepping on anybodys toes.... to locate your tank to the marker light is no more difficult that what they have done. Do it right and do it the Tenniman way! The guy should get an award for such an creative mod!!!!
Alex 1971 Lil' Red 350 SBC 700R4 |
12-17-2003, 12:57 AM | #11 |
FUEL CELL GURU
Not knocking...
anyone's setup. The marker fill location seems a little prone to paint getting chipped or scatched also, fuel spillage on the paint. Many different options and personal preferences. No biggie!
12-17-2003, 02:53 PM | #12 |
Fuelcellguy,
I will agree with you that if you are not carefull you can get paint chips. I haven't had any real problems with gas nozzles (except in Cali) hitting anything in the area to damage the paint. I have had a couple of fuel spills (only in cali) on the side and had to clean them up pretty quick. The way to avoid that with mine at least) is to not 'top it off'. I put the click thing down and when it pops, I don't try and force anymore. I use my bed alot, so I had to have something I could access from the outside, rather than the bed. I also didn't want to cut up my bedside for a fuel door. On another note, I've seen some pics of your work and it is GREAT!! If I ever need a fuel cell, I will definately come to you!!!
12-17-2003, 03:15 PM | #13 |
Self-proclaimed LED man
Ive seen some setups where people used the original filler location, but put a blazer tank under the cab somewhere. They just ran some fule lines through the bottom of the cab and into the fuel tank under the cab. If i ever did one, i would do something like that. Im content with the original filler location, but i hate the fact that my tank is right behind my seat, plus when i fill up it makes me dizzy from all the gas fumes inside the cab!.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
