Old 12-16-2003, 01:52 PM   #1
landon4421
Life is Good !
landon4421's Avatar
Question heater help please !
hey guys my heater is not working, I believe I know why, but I don't want to brake anything. So before I dive in and screw something up I wanted to get some info. One quick question, hopefully it will make sence !
I believe that the flapper thingie in the box in the engine compartment is not working when you push the leaver over, so what I was going to try and do is pop off the little black plastic piece that the cable runs through. To fix the problum, now the question is ....................... Dose that little black plactic piece come off or will I brake it ?
Thanks Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 12-16-2003, 02:08 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
It should just pop off, unless it has been in the sun and has turned brittle.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 12-16-2003, 03:32 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
It should pop off....but mine didn't. Soultion? Duct tape
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-16-2003, 03:33 PM   #4
kevin's 4X4
kevin's 4X4's Avatar
LMAO duct tape Thanks for the info guys !
I am using my son's user name ! landon4421
kevin's 4X4 is offline   Reply With Quote
Old 12-18-2003, 06:02 PM   #5
kevin's 4X4
thanks guys that did the trick. It was so nice riding to work today with heat ! :p
FYI : Kevin's 4x4 is also know as landon4421 !
The boy wants an avatar !
Old 12-18-2003, 06:28 PM   #6
tomsC10R
tomsC10R's Avatar
Could someone explain where this little flapper is. My heater doesn't work either. Figured it'd be worth a shot.
Tom
1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes.
tomsC10R is offline   Reply With Quote
Old 12-18-2003, 06:38 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Assuming non A/C, follow the cable from your "Heat" lever on the control. You'll see it passes thru the header duct underneath the passenger side footwell. There is a plastic piece that covers up the access hole thru which the cable passes. The cable is attached to a flapper that diverts air thru the heater core when set in the hot position.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-18-2003, 06:52 PM   #8
tomsC10R
tomsC10R's Avatar
Thanks CPNE!!
Tom
