12-16-2003, 02:20 PM | #1 |
Progress = 0%
Jim Meyer '60-87 GM Pickup IFS
Anyone see the tech article in the current Classic Trucks Magazine regarding the Jim Meyer bolt-in IFS? Looks like a nice (and complete) kit. Those of you who are interested in a lowered stance/rack and pinion steering/disc brakes might want to check it out. There was no price given in the magazine, but I'm sure it's not cheap.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
12-16-2003, 03:57 PM | #2 |
www.73-87chevytrucks.com
Last time I heard it was right around $1200 or so.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-17-2003, 11:58 AM | #3 |
It looks like a decent set-up. The one thing I didn't like was the upper arms use teflon coated spherical bearings which my guess is will either wear rapidly or squeek alot w/a lot of miles.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-17-2004 at 04:03 PM. |
12-18-2003, 03:31 AM | #4 |
THE QUICKER FIXERUPER
Yeah I read it, it is a a nice setup well designed and uses factory calipers and rotors. And for that base price I would go that route before I notched a crossmember and bought drop spindles the ease and simplicity would be worth it to me. I plan on buying one with shockwaves for my 65 in the verry distant future, if I can ever finish my panel and school.
12-18-2003, 10:55 AM | #5 | |
Happy to be here
12-18-2003, 01:22 PM | #6 |
Trucker.
I would personally rather wait for ART to come out with their tubular UCA/LCA’s(bag ready) and notch the stock crossmember.
12-18-2003, 01:36 PM | #7 | |
belly dragger
I only drive at about 3" off the ground so 4" of lift isn't that bad except it might ride a little stiff |
12-22-2003, 05:04 PM | #8 |
how much of a crossmember drop is this kit? Will it set the frame on the ground? Any body reccomend this over turners kit?
I want my truck done! |
12-22-2003, 11:47 PM | #9 |
With this kit you dont use any of your original parts. It has a new crossmember, control arms, spindles rack and pinion steering parts to hook it up, rotors and calipers and built in motor mounts I would definatley go with this setup over turners. I am allso looking at a kit from scott's.
12-23-2003, 10:36 AM | #10 |
The biggest question is how much difference in ground clearance does each set-up offer?
What would be good to compare is the distance between the lowest part of the crossmember to the bottom of the frame rail @ spindle C/L on a stock set-up vs. Turners, & J.Meyers.
12-23-2003, 03:35 PM | #11 | |
01-16-2004, 09:51 PM | #12 |
Jim Meyers is one of the nicest front ends ive seen. All bolt on, zero bump steer, Adjustable ride height,and GM based rather than Mustang II, other than the rack. It uses Impalla/ caprice rotors and spindles. The only drawback is the price $3200.00 with the coil overs, Shockwaves are even more! Even the stage one kit with no spindles, rotors, or rack is $2600.00
Mark 72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction 05' GMC Sierra Denali LQ9 |
