Old 10-27-2020, 03:53 AM   #1
zschary
Junior Member
amp gauge swap question
there are those two fuses under the hood that run back from the shunt to the amp gauge.. can i remove both of them if i am not using the amp gauge or do the wires power something else?
thanks in advance if you know...
zschary is offline   Reply With Quote
Old 10-27-2020, 04:42 AM   #2
RustyPile
RustyPile's Avatar
Re: amp gauge swap question
"Not using the amp gauge"??? Why?? You can remove the fuses if you want, BUT -- You'll not have any way to monitor the charging system if you do.. IMO, what you're proposing is not a good idea...
RustyPile is offline   Reply With Quote
Old 10-27-2020, 08:26 AM   #3
zschary
Junior Member
i have new gauges and have put in a newer engine in it.. Want to run a volt meter instead.
so is it ok to get rid of those wires or do they feed something else? i think there is one in in the original wiring that goes to the positive side of coil and another near the drivers fender.
thank you
Old 10-27-2020, 09:19 PM   #4
zschary
Junior Member
does someone know exactly what they go to and how its wired?
Old 10-27-2020, 09:46 PM   #5
dmjlambert
dmjlambert's Avatar
The wires that have fuse holders by the battery and by the driver side headlamp are connected to the ammeter and nothing else. You can remove them. Or you can remove one of them and use the other one for your voltmeter.
dmjlambert is online now   Reply With Quote
Old 10-27-2020, 09:49 PM   #6
dmjlambert
dmjlambert's Avatar
Or you can use them to power a couple of things that need 4 amp fuse protected un-switched power.
Old 10-27-2020, 10:22 PM   #7
jocko
jocko's Avatar
You may some useful info in these threads. Member tbone1964 might be able to answer your question directly, he's done many of these conversions and has sold kits for the conversion as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=653967
http://67-72chevytrucks.com/vboard/s...d.php?t=630289
http://67-72chevytrucks.com/vboard/s...d.php?t=653334
Old 10-28-2020, 05:20 AM   #8
zschary
Junior Member
cool.. good to know, i wonder if 4 amp is enough for the washer pump that will be on the drivers firewall.. prob not..
thanks
