Old 10-27-2020, 04:22 PM   #1
scf100
scf100's Avatar
Dumb question on adding tach cluster
so on a 1971 C10 that did not come with a factory tach how hard is it to hook up the tach to one of Classic Instruments new clusters with a tach?
Thanks,
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 10-27-2020, 06:56 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Dumb question on adding tach cluster
The factory tach's had a 2 wire harness which you can buy on line. The one in my picture was a stock one. 1 wire goes to the distributer marked on a HEI as tach and the other goes to the fuse block under the dash on any place that gets 12 volts with the truck running.
As the picture shows it's separate from the other harness.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
