Old 10-29-2020, 03:16 PM   #1
skip99
skip99's Avatar
Throttle cable
I want to have my throttle cable look like this, so the question is, can these universal style be cut down, even if its stainless braid?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 10-29-2020, 03:31 PM   #2
Tempest67
Tempest67's Avatar
Re: Throttle cable
Yes , I used the Lokar cable and it can be cut it to any length.
You do not want the cable to be tight to the firewall, if a motor mount breaks, or there is any movement with the engine for any reason, that will pull on the throttle and away you go.
I installed mine with some slack.
nevermind the screw driver in the pic, I was using it to locate the fender brace holes through the insulation on the inside.....
Tempest67 is offline   Reply With Quote
Old 10-29-2020, 04:19 PM   #3
G&R's57GMC
G&R's57GMC's Avatar
Re: Throttle cable
Ya what he said :-)
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 10-29-2020, 08:17 PM   #4
skip99
skip99's Avatar
Re: Throttle cable
Great! Thanks
Tami's 51 build
Old 10-29-2020, 09:55 PM   #5
MiraclePieCo
MiraclePieCo's Avatar
Re: Throttle cable
Braided stainless is hard to cut cleanly. I wrap it in masking tape and use a die grinder to cut around the taped area. Leave the tape on until you slip the housing into the fitting - this keeps all the little wire ends contained. I don't know if this is the best method, but I've muddled through using it.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-30-2020, 03:03 AM   #6
mr48chev
mr48chev's Avatar
Re: Throttle cable
^^^ that is standard procedure for cutting braided stainless.
Summit shows 278 Throttle cables both Stainless and black and ?? Probably some oem style ones in there too. Lots of Universal ones. Some of the Mr Gasket ones have a friendly price but it looks like you need to figure out what ends you need and sort though and find the ones that has those ends. Some of the more spendy Mr Gasket look to have extra ends in them to connect to different setups. Then there are the Lokar ones that are double the price or more.
https://www.summitracing.com/search/...al+Terms+S+-+Z
My ongoing truck projects:
Old 11-01-2020, 05:16 PM   #7
_Ogre
_Ogre's Avatar
Re: Throttle cable
Originally Posted by G&R's57GMC View Post
Ya what he said :-)
yeah, what he said.
needs some slack
shop air compressor timer
Old 11-01-2020, 11:53 PM   #8
Black93GT
Black93GT's Avatar
Re: Throttle cable
My go-to for cutting braided cable is the plasma cutter. It both makes a clean cut but also welds the ends.
'49 3600 build
SBC 350, a T-5 and some patina
Black93GT is offline   Reply With Quote
Old 11-07-2020, 09:44 PM   #9
mr48chev
mr48chev's Avatar
Re: Throttle cable
Cool, I never though of that but my Plama cutter could handle that.
Old 11-11-2020, 10:47 AM   #10
my56chevytruck
my56chevytruck's Avatar
Re: Throttle cable
Originally Posted by _Ogre View Post
yeah, what he said.
needs some slack
yeah, what OGRE said!!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 11-11-2020, 11:30 AM   #11
3757chevy
3757chevy's Avatar
Re: Throttle cable
Here's a picture of my cable on my '35. I used the tape and die grinder, no plasma cutter
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
