Old 12-16-2003, 06:43 PM   #1
MAVIS
front dana 44
I KNOW THAT THIS HAS BEEN ASKED BEFORE, BUT CAN'T FIND IT WHEN I SEARCH. I HAVE 1970 K10 I WANT TO KNOW WHAT YEAR FRONT AXLE WILL FIT SO I CAN RUN DISK BRAKE, NOT ALSO WHAT YEARS FIT BUT WHAT IS PREFERRED.
THANKS MAVIS
MAVIS is offline   Reply With Quote
Old 12-16-2003, 08:35 PM   #2
nu2-72
Dana 44's were the same for many years. 71-72 are disc and dirrect bolt in.
73 and up are supposed to have straight axle shafts, not tapered, so they are stronger. Try 73 to 79. Pick one.
Anyone else have better info for him?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 12-16-2003, 08:49 PM   #3
Destructo
73-87 all have the same thing except for the very minor difference of D44 and Corp 10bolt. some 79's also have corporate front ends, but theres not enough difference to matter. If you go with a 73-up front end then whichever you find a better deal on I say go for, their all the same.
Destructo is offline   Reply With Quote
Old 12-16-2003, 09:35 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The only thing to concern yourself with would be getting the correct brake lines which change from standard to metric and the banjo fitting is slightly different between the 44 and 10 bolt.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-17-2003, 01:11 AM   #5
1969 GMC
1969 GMC's Avatar
I have heard that the internals of the 10 bolt are not as strong as the dana 44.
also, you can upgrade to a dana 60 if you can find one. these come from '77-'91 K/30's and all of the military CUCV's except the blazer.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-17-2003, 01:32 AM   #6
Destructo
Why in the world are D60's so expensive and hard to find? They came in all 73-88 1-ton trucks, I know theres tons of those out there.
Old 12-18-2003, 01:54 AM   #7
1969 GMC
1969 GMC's Avatar
they started making the K/30 in '77 or '78, before that all one ton 4x4's were conversions. They ran all the way til '91 in the V-series one ton crewcabs. Plus, all the CUCV trucks.
I think the reason you don't see alot is because alot of the trucks are still being worked. And people grab up the dana 60's as soon as they hit the junkyards. jsut take a look at coloradoK5.com's forums, almost all the people there run dana 60 fronts.
I would like to run a dana 60 frontend eventually, but it would cost me the same to run a disk brake dana 44 with the lift I want. I'd like to lift 6", and crossover steering is highly recommended. doing crossover steering on a dana 44 is $$$. it's really cheap for the 60. so, I figure why not do it? more beef for around the same cost. and i get disks either way.
1969 GMC K2500
1996 Honda Accord
Old 12-19-2003, 02:39 AM   #8
1FaastC10
1FaastC10's Avatar
Originally posted by ChevyGuyBC
i belive mine is out of a 80 my dana 44, is this okay? it seems to handle the 39s on anything except rocks but i haven't really tried those yet
got any pictures of your front diff? i've never seen a '44 in anything newer than '77
1FaastC10 is offline   Reply With Quote
Old 12-19-2003, 06:32 AM   #9
1969 GMC
1969 GMC's Avatar
I plan to snatch up a 60 or 70 as well. what exactly would be the best year for a 60 and where do i find a 70?
All years of dana 60 are good; if you try to shop for a certain year good luck because they are so hard to find.
Dana 70 front axles...hmm...I have only seen these under 3 things: old (like early 60's) W300 Power Wagons, some IHC 1 ton 4x4 pickups, and one in a newer 4x4 motorhome (based on a Ford E-350). Core charge for these axles is like $2k; IMO they are not worth it unless you can find one, and even then, sell it and buy 3 dana 60's.
I think if you do any hardcore offroading or mudding in some deep mud, then you will need a stronger front axle.
1969 GMC K2500
1996 Honda Accord
Old 12-19-2003, 07:42 AM   #10
Milenko72276
I wouldn't trade a 44 for a 70 front,70 fronts are the exact same as a 60 except for the ring gear.And good luck finding one with open knuckles,they are all that ball-in-socket junk.There are a few on e-bay though if you really wanted one.
72' Camper Special,454,th350,np205,4.56 locker,dana44 with spool,13" of lift and 44" boggers.soon to be 23" with rear disc brakes
Milenko72276 is offline   Reply With Quote
Old 12-19-2003, 12:17 PM   #11
Destructo
http://www3.telus.net/loudmalibu/Fil...v/DSC00056.JPG
buddy who i bought it off said it came out of a 80 3/4 ton but who knows..
So dana44 don't have a round higs head? That one looks kinda like the shape of my 12 bolt in the back.
Old 12-19-2003, 12:41 PM   #12
drink2mny
drink2mny's Avatar
I know I'm late in the game here. I own a 60 in front of my '86 with crossoversteering.
I could get pics if people want to se the difference.
I got to say not All 60's are good..
not sure what year but they changed them from a kingpin to a ball joint style somewhere near the 90's. I was told not as strong with the ball joints..
Support The Board
drink2mny is offline   Reply With Quote
Old 12-19-2003, 12:53 PM   #13
Destructo
Yeah, ball joints are for sure weaker than the king pins and would wear out faster with large tires.
So do Dana 44 axle housings not have a round cover like a regular ol 10 bolt?
Old 12-19-2003, 01:16 PM   #14
drink2mny
drink2mny's Avatar
Here is a link to show the difference
http://www.coloradok5.com/axleguide.shtml
Support The Board
Old 12-20-2003, 04:46 AM   #15
1969 GMC
1969 GMC's Avatar
it's a dana 44, look at this pic:
if it was a 10 bolt, it would have the little "ears" under the diff
1969 GMC K2500
1996 Honda Accord
Old 12-20-2003, 06:23 PM   #16
DaHateTank
Anyone know, for sure, what year they changed to the larger steering U-joints?? ('73, I think???)
I have a '70 front end (with discs) and it has the smaller 1.0625 cap u-joints. The later model D44 I have has 1.1875" caps on the joints.
I checked an online parts supplier, but they listed the same joint for everything, and Im sure thats not right...
I would suggest that anyone swapping an axle steer clear of the early, small joint versions...
some prefer the 10 bolt over the small joint D44s
However, these early axles also seem to have the correct knuckles for the crossover steering setup...
I think you can swap knuckles??
-M
DaHateTank is offline   Reply With Quote
