10-31-2020, 02:29 PM | #1 |
Moderator
NOS Built Speed Warning, Tach, 80lb Oil, Vac, Woodgrain Cluster
Selling a crown jewel here. I had built this for an NOS restoration that changed direction.
What’s included in this cluster: NOS Woodgrain Bezel NOS Temp Gauge NOS Fuel Gauge NOS Voltage Gauge NOS 8 cyl. Tachometer NOS Tach Style Circuit Board NOS 80 lb. Oil Gauge Restored/serviced Speed minder Gauge with back tin Low mile vacuum gauge & lens (look NOS) NOS speed warning bezel nut and knob Speed warning buzzer and harness Aftermarket Tach wire This was a “no holding back” build, I have $1600 in this thing. $1550 Shipped to you. Posted via Mobile Device |
10-31-2020, 02:32 PM | #2 |
Moderator
More pics
10-31-2020, 02:37 PM | #3 |
Moderator
...more
10-31-2020, 02:40 PM | #4 |
Moderator
And some more.
10-31-2020, 03:22 PM | #5 |
Re: NOS Built Speed Warning, Tach, 80lb Oil, Vac, Woodgrain Cluster
That is quite a nice piece. Good luck with your sale.
11-05-2020, 04:32 AM | #6 |
Moderator
Dropping it down some to $1375 shipped. Great for those Sunday drivers.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
11-05-2020, 10:59 AM | #7 |
How hard would it be to get this to work on a LS swap
11-05-2020, 06:10 PM | #8 |
Moderator
Using OEM gauges on a newer motor will mostly work, you will have to change the oil sensor to an OEM sensor that has either been machined to screw into a newer block, or use an adapter (mixed reviews using this method). The only other issue may be with the tach. I'm not sure if the LS would need a tach resistor, otherwise incorrect readings or tach damage may occur.
11-05-2020, 11:32 PM | #9 |
Impressive!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
11-06-2020, 01:18 PM | #10 |
And Don't Call Me Shirley
What's the air filler thingy above the speedo? I've never seen that.
Rick Tucker 1969 C20/Custom Camper (the Green Machine)Sold 1970 GMC 4000 COE (future Ramp Truck) 1972 K10 Longbed (restoration begins June 2020) |
11-06-2020, 02:06 PM | #11 | |
J/k it’s to adjust the speed warning. White pointer on mph gauge
Some progress is better then no progress |
11-15-2020, 11:21 AM | #12 |
Moderator
Sunday morning bump for those Sunday drivers who like to mind their speed.
$1350 shipped.
11-15-2020, 01:35 PM | #13 |
Very nice.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
11-20-2020, 08:00 PM | #14 |
Moderator
$1,325 Friday Bump...
11-21-2020, 08:39 AM | #15 |
I'll be the dummy in the crowd and ask why the bezel isn't chrome ?
11-21-2020, 09:36 AM | #16 |
Moderator
11-21-2020, 12:48 PM | #17 |
I don't think it was just service parts bezels, as I had a loaded 67 CST with factory speed warning dash, and there was no chrome on bezel either, and 99% certain it was a factory cluster. Mine was black/silver. I have never seen a 67 with chrome bezel from the factory, and I have seen many of them over the years. Not saying there were none, just saying I have never seen one. Pretty sure my truck was a very late 67, as it had the bright eyebrow mouldings, which many say never came till 68. Sold it nearly 40 years ago sadly.
11-21-2020, 12:57 PM | #18 |
Moderator
I should have added that the "woodgrain" replacement bezels were a service part. GM had a chrome edged bezel prior to this later release. The 67-68 bezels were painted argent silver but none were woodgrain.
