Old 11-01-2020, 02:16 AM   #1
flashed
Exhaust manifold Butterfly on 72 K10 ?? Driver Side
Anyone know what Im talking about and where to get one ? Trying to get my truck back together and it didnt have one to start with . Had a Donut gasket squeezed in there . Any help much appreciated .
flashed is offline   Reply With Quote
Old 11-01-2020, 10:16 AM   #2
i82much
Re: Exhaust manifold Butterfly on 72 K10 ?? Driver Side
heat riser valve. i had one installed by a local muffler shop, they had it in stock.
i82much is offline   Reply With Quote
Old 11-01-2020, 10:30 AM   #3
flashed
That helps me a lot knowing what it's called. Thanks . Will check with my local shop tomorrow .
Old 11-01-2020, 10:43 AM   #4
hotsam
hotsam's Avatar
I may have a spare one. I'd have to check and see and also what kind of shape it was in . you would be welcome to it free. If shipping wouldn't kill you on it.
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold)
1985 K30 Dump Truck
1986 Jeep CJ-7
1955 2 door 210 post
hotsam is offline   Reply With Quote
Old 11-01-2020, 10:49 AM   #5
i82much
it is helpful for cold weather, but you can’t have the crossover blocked.
Old 11-01-2020, 01:12 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
As mentioned above, if the intake manifold gaskets have the block off plates installed, then there is no point to put that exhaust valve back in. Plus you would need the thermostatic valve that controls it.
Old 11-01-2020, 05:54 PM   #7
i82much
by “thermostatic valve” do you mean the bimetallic coil on the heat riser valve itself, or something else? i thought the coil came with the valve, but maybe you are referring to something else?
also, i think there may be vacuum operated exhaust valves but not sure if those are oem or appropriate for your application.
Old 11-01-2020, 07:22 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It may not make a difference, but my K20's heat riser valve was on the passenger's side. It was giving trouble many years ago (too long ago for me to remember) and I ended up removing it. Haven't missed it one bit. The truck needs to warm up a little in cold weather, but it did before anyway.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-01-2020, 11:03 PM   #9
flashed
I would gladly pay shipping if you have it plus some , just want to get it together .
Old 11-01-2020, 11:27 PM   #10
REDROCKER652002
If nobody else has one, i think i have one from my son's 69. I was not hooked up, so not sure if it is complete, but I can send pics if need be.
REDROCKER652002 is offline   Reply With Quote
Old 11-02-2020, 12:37 AM   #11
hotsam
hotsam's Avatar
I'll check tomorrow for you
1985 K30 Dump Truck
1986 Jeep CJ-7
Old 11-02-2020, 05:25 PM   #12
hotsam
hotsam's Avatar
I looked and I do not have a spare one on my old chassis. Sorry !
1985 K30 Dump Truck
1986 Jeep CJ-7
