11-01-2020, 04:36 PM | #1 |
New wiring with fuse block
Had this 12 circut kwikwire for at least 14 years, finally wiring the truck, it came with a gm column ign switch plug in, which ill just cut off, im using an ididit column with dash ign. ..but..the column has this plug in for turn signals horn, hazard, etc...the question is do any newer wiring kits come with the female to this connector, or do i just grab a female from a parts car and wire it up? Wireing is not an issue, but i also dont need about half of hat this kit has, So might just buy another, or better one?
11-01-2020, 05:39 PM | #2 |
Re: New wiring with fuse block
I actually just found the female part on an old trans am harness i had, so thats good if i go that way
11-02-2020, 05:46 AM | #3 |
Every wiring kit I've ever bought included one of those GM column plugs. I probably have several in my shop; I never use them.
1951 Chevy Panel Truck |
11-03-2020, 08:28 AM | #4 |
Not terribly hard to find. I used the american wiring steering harness one and crimped some new wires to match.
https://www.summitracing.com/parts/a...BoCS28QAvD_BwE
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
11-03-2020, 06:05 PM | #5 |
The Ididit columns come with a GM switch with the GM plug. there are three models of GM turn signal plugs that I know of, The early rounded one, the earier flat ones and the later flat ones.
There are adapter plugs to mix and match the different designs.
