Old 11-02-2020, 10:54 AM   #1
1967 Aqua C10
Is my bed size "normal".
Good Morning,
I am trying to find a topper, camper shell, cap, etc. for my 1968 C10. I can't seem to find one the right size.
From the outside of my bed rails it is 71" wide and the length from outside of the front bed rail to the back of my closed tailgate is 91".
The width I can find, but the length at 7.5 feet I am having trouble with.
Is this a "normal" bed size for a 1968 C10?
1967 Aqua C10 is offline   Reply With Quote
Old 11-02-2020, 10:20 PM   #2
pwdcougar
pwdcougar's Avatar
Re: Is my bed size "normal".
You are going to be better off posting in the pickup section. This section is primarily Suburban specific.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 11-03-2020, 01:48 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Moved it.
LockDoc
Leon
Old 11-03-2020, 01:59 AM   #4
68bowtie
68bowtie's Avatar
Seems like maybe the rear of the bed section was shortened?
Old 11-03-2020, 05:35 AM   #5
Sheepdip
Sheepdip's Avatar
Originally Posted by 1967 Aqua C10 View Post
Good Morning,
It may be just the pic but your rear wheel doesn't look centered in the well opening.
Sheepdip is offline   Reply With Quote
Old 11-03-2020, 01:18 PM   #6
TruDom
doesn't look it is at all. What in tarnation is going on here. did someone only shorten the back half of the bed but then why is the wheel well not centered. how far back do the frame rails go back?
Look up the vin and see what the truck was originally.
TruDom is offline   Reply With Quote
Old 11-03-2020, 02:59 PM   #7
kwmech
Post up more pics at different angles. Maybe a couple of the frame also
Old 11-03-2020, 03:35 PM   #8
TwoFiftyShifter
C10 bobber?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 11-03-2020, 04:02 PM   #9
MySons68C20
MySons68C20's Avatar
Our 68 C20 measures just over 96".
MySons68C20 is offline   Reply With Quote
Old 11-03-2020, 11:30 PM   #10
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Originally Posted by LockDoc View Post
Moved it.
LockDoc
Good thing I saw this post! I thought I had stepped into the Twilight Zone there for a couple of posts.
And yes, the rear wheels look way forward in the wheel wells. A pic of them from straight across the axle would help.
~Steven
Simi Valley, CA
Old 11-04-2020, 03:37 AM   #11
gmc684x4
Rear wheels are definitely off to far forword in the wheel well
You need to check your wheel base measurements as well
115 sb 127 lb as posted in the diagram
Does the frame look original ?
Any cuts and welds under the cab ?
I have a bobbed c10 looks like a sb with out a bed until you realize rear wheels are 10 inchs to far back
gmc684x4 is offline   Reply With Quote
