11-03-2020, 06:14 PM | #1 |
Old member
Brake pedal
I readjusted my brake pedal today. I put the rod from the master assembly as far out as I felt comfortable with. Tightened up the jam nut and it feels much better and has room under the pedal now when I step on the brakes. The disc brakes still don't seem to be as good as I had wanted but they do stop the truck.
I have never seen a truck with both holes in the brake pedal assembly that so many talk about, plus my truck in a factory disc brake truck to begin with and it only has 1 hole. It may not be perfect but it does feel better as far as pedal feel now.
11-03-2020, 06:32 PM | #2 |
laying low
Re: Brake pedal
That's about what I gained by adjusting mine too. I've never seen a pedal with two holes either.
And don't you have a late model master cylinder on yours?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-03-2020, 07:35 PM | #3 |
Old member
Re: Brake pedal
I have the 4 wheel master cylinder for disc brakes yes.
11-04-2020, 12:18 PM | #4 |
Old member
Re: Brake pedal
It took a bit but I found what I was looking for. This is out of the manual for the brakes. So after adjusting the pedal rod I have plenty of distance from the floor.
